Dashboard Dimmer
Posted: Mon Nov 09, 2009 12:17 pm
by thepickles
Hi all ,
does the dash have a dimmer :?: :?:
my dash is not very bright at all at night, easy fix :?: :?:
cheers
Steve :D
Re: Dashboard Dimmer
Posted: Mon Nov 09, 2009 12:56 pm
by daveblueozzie
no dimmer, you can change all the bulbs to see if that works or
buy some white dials that light up blue or green, they have a dimmer on them.about £40.
Posted: Mon Nov 09, 2009 1:02 pm
by mikexgough
when I changed to the plasma dials I found an mph dial over the km dial.....which caused my dials to be as dull as dishwater...... either led's or even better the plasma dials as DBO says
Posted: Mon Nov 09, 2009 1:29 pm
by stilldesperate
Steve :D
Hi Steve,
The bulbs should be 3.5w (from memory) check to see if lower wattage bulbs have been used.
You should also see 12v to the bulbs. Any less will make them dim.
Other than that, is there a build-up of crud obscuring the light / has someone put a second dial face over the original, reducing the brightness?
Hope this helps,
SD
