Topping up with coolant/anti-freeze
Posted: Tue Oct 13, 2009 6:41 pm
by pilajake
My Resevoir tank is just below "low" on a cold engine.
Can i top up with coolant/antifreeze to the full level rather than a complete change and what is the best coolant to use :?:
There is no obvious leak just evaporation of water i hope.
regards
Sue & John
Re: Topping up with coolant/anti-freeze
Posted: Tue Oct 13, 2009 6:51 pm
by scanner
As has been said many times before, unless you know exactly what is already in there it isn't "safe" to top up with anything else.
Not all anti-freezes will mix and some can cause disastrous problems if mixed because their compositions are totally incompatible.
E.G.
This sort of problem.
http://autorepair.about.com/cs/coolings ... 52601c.htm
Dexcool® is just a brand name for a certain type of antifreeze which is known to cause problems if mixed with another incompatible one.
Posted: Tue Oct 13, 2009 6:53 pm
by westonwarrior
What you realy need is the same as already have in.
However if you dont know I would just use water as that little bit cant make that much difference
But I freely admit, I know nothing
Posted: Tue Oct 13, 2009 7:02 pm
by scanner
Here's what Bluecol say (and they should know)
http://www.bluecol.co.uk/index.cfm?page=75
Posted: Tue Oct 13, 2009 7:03 pm
by pilajake
scanner wrote:As has been said many times before, unless you know exactly what is already in there it isn't "safe" to top up with anything else.
E.G.
Thanks it looks like serious problems will happen
I have only topped it once before in three years, so i think i should be safe [-o< to top up with water until i give it a complete change.
Posted: Tue Oct 13, 2009 7:07 pm
by missfixit70
3 years? - time for a change then, with a proper flush.
Posted: Tue Oct 13, 2009 10:15 pm
missfixit70 wrote:3 years? - time for a change then, with a proper flush.
:oops: nearly 3 years for me too. Must bite the bullet and do it. :oops:
Posted: Wed Oct 14, 2009 10:21 am
by Biobongo
pilajake wrote:My Resevoir tank is just below "low" on a cold engine.
regards
Sue & John
lidi has a coolant antifreez tester at presant:
http://www.lidl.co.uk/uk/home.nsf/pages ... Tester.ar1
