burning smell when going up very steep hill!!
Posted: Fri Oct 02, 2009 9:01 pm
by hogggman
hi all,
when in wales fairly recently,we went up a series of VERY steep hills in the bongo,probably about half a mile of twisty turny,very very steep bits,and when we were nearing the top,i noticed a burning smell,which quickly went away when we levelled out.it was similar to a burning clutch,but does an automatic suffer in the same way?i haven`t checked the autobox fluid in a while,but when i did,it was a clear reddish colour.
any thoughts?
thankyou
jamie
Re: burning smell when going up very steep hill!!
Posted: Fri Oct 02, 2009 9:08 pm
by missfixit70
You're not alone Jamie, have a squint at the first few of these -
http://www.igmaynard.co.uk/bongo/forum/ ... mit=Search
Posted: Sat Oct 03, 2009 7:54 am
by wonkanoby
so was mine
but under the bit the dip stick reaches was a pool of grey sludge
and metal particles all around magnet in the base
dont go by dipstick colour
Posted: Sat Oct 03, 2009 11:00 am
by dandywarhol
I find there's a rubbery smell after long steep ascents - usually the tyres getting hot and starting to wear
Posted: Sat Oct 03, 2009 11:43 am
by Ron Miel
dandywarhol wrote:I find there's a rubbery smell after long steep ascents - usually the tyres getting hot and starting to wear
Ditto dandy.
Posted: Sat Oct 03, 2009 12:01 pm
by missfixit70
wonkanoby wrote:but when i did,it was a clear reddish colour
so was mine
Good point, if you haven't had the ATF changed Jamie (properly, ie drop the pan) then it's probably time to do it anyway, mine was a nice red colour when I changed it, but not so at the bottom -
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=30096 . Possibly nowt to do with the smell, but it'll be a nicer drive
Posted: Sat Oct 03, 2009 12:04 pm
by bigdaddycain
I wonder if the oil cooler for the autobox is functioning correctly? Hot oil smells!
Posted: Sat Oct 03, 2009 12:07 pm
by missfixit70
bigdaddycain wrote:I wonder if the oil cooler for the autobox is functioning correctly? Hot oil smells!
Spose that could be the case if the ATF hasn't been changed for a while, they aren't big pipes up to the cooler in the bottom of the rad, don't know how easily they could block, partially or fully?
Posted: Sat Oct 03, 2009 12:31 pm
by bigdaddycain
I suppose if the magnet in the pan is bunged up enough, i 'm guessing the pipes to the cooler could possibly be reduced in inner diameter slowing down the oil flow, hence reducing the efficiency of the rather small cooler.
Posted: Sat Oct 03, 2009 12:40 pm
by missfixit70
Or I suppose if the rad is a bit sludged at the bottom it won't be cooling as well as it should, I'm veering more & more toward a decent external oil cooler for the ATF
Posted: Sat Oct 03, 2009 9:18 pm
by johnny7
I have noticed this when going up some steep passes in europe. I put it down to the spongy matting on the plastic undertray being contaminated by oil spills on it and getting hot then smelling.
Posted: Sun Oct 04, 2009 3:08 pm
by hogggman
hi,
thanks for the advice.i guess i really need to drop the bottom of the gearbox off and clean everything out.i`m a bit nervous about trying to get the cork gasket off in one piece and use it again,but i feel a sunday morning maintenance sessuion coming on!!
thanks again.
jamie
Posted: Sun Oct 04, 2009 3:19 pm
by missfixit70
Just slacken off the bolts, tap it & the gasket should be stuck to the bottom pan, pretty sure it's not a cork gasket from memory & looking at the pics again on the link I posted on changing the ATF.
Posted: Sun Oct 04, 2009 3:29 pm
by hogggman
hi kirsty,
thanks for that,i will hopefully tackle it next weekend.
thanks
jamie
Posted: Sun Oct 04, 2009 5:19 pm
by manners
I used to get a rubbery burning smell on my V6 if i booted it a bit and it dropped down a gear, but since changing all the belts it doesn't do it any more, maybe the alt' or air con belts are slipping a bit?
