removing grill
Posted: Sun Sep 20, 2009 4:14 pm
by Barley 1981
Hi, My Bongo, like many others is suffering from worn paint on the front grill....I would like to spray it with the matt silver paint to tidy it up.
Can this be removed easily for me to spray it?
Tanya
Re: removing grill
Posted: Sun Sep 20, 2009 4:16 pm
by daveblueozzie
Dead easy to remove, if i remember correctly, five push clips and 1 screw.
Re: removing grill
Posted: Sun Sep 20, 2009 4:17 pm
by mikexgough
yes it's very easy....... a couple of screws and some click in clips....with the clips they have to be pressed in and the grill eased forward as you release their grip....then lift out....
Re: removing grill
Posted: Mon Sep 21, 2009 11:28 am
by bigdaddycain
It'll take longer to mask the chrome "M" mazda insignia than it will to remove the grille!
Re: removing grill
Posted: Mon Sep 21, 2009 1:17 pm
by Barley 1981
Yes it took 1 minute to remove the grill (1 screw and some clips) and 5 minutes to sellotape the mazda badge!!
All sprayed and back on the um bongo! looks fab! very chuffed.
Tanya
Re: removing grill
Posted: Mon Sep 21, 2009 6:40 pm
by dom_e
I've recently doneb this as well. It's easy to get the grille off as has been described. I think it's worth removing the badge (just dremel/cut off the tab at the back where it's melted on). It is easy to glue it back on with some epoxy.
Re: removing grill
Posted: Mon Sep 21, 2009 11:56 pm
by Simon Jones
I recently found that you don't need to press the 5 lugs in as they are actually the springy bits that fit into recepticles on the van, so they are just like little spring loaded catches. Just undo the screw & gently ease it forward.
