battery removal with no loss of 12volts?
FREDA MIND
Post by FREDA MIND » Tue Sep 15, 2009 3:18 pm
hi guys,
another job i need to do is remove the battery so i can clean and rust proof the battery tray(slight corrosion present)
i need to do this without losing 12v from the car as i have no code for the aftermarket stereo.i have a spare battery and jump leads but i recall if done incorrectly you double the voltage to 24V!!!! #-o
can anyone help me? [-o<
have yourself a midlife chrisis,,,,go buy a bongo!
Re: battery removal with no loss of 12volts?
Post by Muzorewa » Tue Sep 15, 2009 3:28 pm
You need to connect in parallel, not series. Positive to positive, negative to negative :wink:
dave_aber
Post by dave_aber » Tue Sep 15, 2009 3:55 pm
.... and insulate the red jump lead well........
Image...Image
dandywarhol
Post by dandywarhol » Tue Sep 15, 2009 4:01 pm
FREDA MIND
Post by FREDA MIND » Tue Sep 15, 2009 4:17 pm
wow thanks for swift responce fello bongo freaks!
perfect!!!
:wink:
Colin H F
Post by Colin H F » Tue Sep 15, 2009 7:55 pm
Am I correct in saying that once the engine is running you can dissconect the battery and the alternator will keep everthing ticking over the same? Colin
Post by g8dhe » Tue Sep 15, 2009 8:46 pm
Its quite possible that the alternator will attempt to raise the voltage, higher than would be advisable, in an attempt to push a charging current through the battery. The alternator will have a cut-off voltage probably about 15 perhaps 16 volts - do you wish to try this out and report back to us all ?
Scott
Post by Scott » Wed Sep 16, 2009 11:28 am
newbie wrote:Am I correct in saying that once the engine is running you can dissconect the battery and the alternator will keep everthing ticking over the same? Colin
I have done this a few times when I haven't had the code available (not on a bongo mind you) I then shoved a sock over the positive lead to insulate it (un-worn sock of course) and it has worked fine :)
But as said, haven't tried it on the bongo yet as have had no need... YET! :lol:
The user formerly known as csmcqueen ;)
スコット
Scott
Post by Scott » Wed Sep 16, 2009 11:32 am
this is a really clever idea tbh, but i'm not sure how it would be with split chargers, leisure batteries and re-wired fuse boxes :o
スコット
dave_aber
Post by dave_aber » Wed Sep 16, 2009 11:59 am
If your engine isn't running, then the split charge relay will be in the relaxed state - i.e. batteries are not connected together.
The Halfords dooberie will inject 12v into the cig socket, so that 12v will end up back-feeding the fuse box that the cig socket is supplied from, this will be either the main or the leisure battery but not both (depends how you have modified the wiring to take advantage of the leisure battery).
So, if the stereo and the cig socket are on the same battery, and thus on the same fuse set, then the halfords dooberie will keep 12v going to your stereo and keep the code.
remember that there are normally 2 supplies to a stereo, permanent 12v (for memory, security code, etc) and switched 12v to run it normally. If you have each feed off a different battery then you would need to be clear about what is going where first.
Image...Image
FREDA MIND
Post by FREDA MIND » Wed Sep 16, 2009 1:13 pm
thanks guys , top stuff!!!! :)
rick
