gearbox oil level over full???
FREDA MIND
Post by FREDA MIND » Mon Sep 14, 2009 2:41 pm
Hi there, i have recently bought a nice freda 2.5l d auto which i am very pleased with,however when checking all the fluid levels i noticed the gearbox oil level appears considerably over full to the indications on the dip stick(i inch above full!)am i correct to assume the levels on dip stick are with the engine off and gearbox static and vehicle level? assuming it is overfull, could this have damaged the gearbox in anyway
please help kindest regards new member rick :?
have yourself a midlife chrisis,,,,go buy a bongo!
Re: gearbox oil level over full???
Post by missfixit70 » Mon Sep 14, 2009 2:48 pm
Level must be checked with the gearbox warm - ie having driven for at least 20 minutes, on the level, wheels chocked Hand & footbrake on, range slowly through all the gears, then leave it in D to take the level (less bubbling/turbulunce apparantly), it should be a reddish colour.
Welcome to the forum :D
Post by bigdaddycain » Mon Sep 14, 2009 4:40 pm
Hi Freda mind... Try checking the level with the gearbox warm,box in D, brake on wheels chocked etc... You'll find that the level drops a bit... Too high a level is as bad as too low a level. If you have access to an extraction pump, then extract a little ATF at a time till the level is correct. If you have a PELA pump, this can be achieved via the ATF dipstick tube).
sparkymik
Post by sparkymik » Mon Sep 14, 2009 8:42 pm
Pipped at the post again :lol:
Sparky
Post by bigdaddycain » Mon Sep 14, 2009 8:50 pm
\:D/ Wahay! :wink:
FREDA MIND
Post by FREDA MIND » Tue Sep 15, 2009 1:10 pm
thanks for your responce guys, great stuff!!
im going to make this job top of my to do list,i have only just bought my freda which was imported last year and for peace of mind think ill treat it to a change of atf ,clean the filter and de sludge as you described in your great post kirsty!
the colour on the dip stick dosnt look light pink ,more pale yellow so im a little concerned if it has the correct oil in it,
the gear box runs lovely and smooth and i want to keep it that way,
where could i buy a pela pump?
i have friends in the car trade so they may loan me one,
think its pretty much a must have for this type of job!
oh p.s i think im in love with my new freda, is this normal behavior or should i get more???? :lol:
Post by bigdaddycain » Thu Sep 17, 2009 1:32 pm
Depending on your location, you are more than welcome to come and lend my pump... :wink:
FREDA MIND
Post by FREDA MIND » Thu Sep 17, 2009 1:34 pm
bigdaddycain wrote:Depending on your location, you are more than welcome to come and lend my pump... :wink:
very kind dude , where are you???
cheers rick :wink:
