Lumpy starting
Posted: Sat Aug 29, 2009 12:39 pm
by jonb
Hi all, I've just changed the glow plugs on my Bongo as starting was becoming a bit "lumpy". I've had the Bongo five years and new glow plugs have always sorted this problem. This time however, although she starts with no problems at all, it's still a bit "lumpy" after starting and not like it usually is after new glow plugs.
Question: will a battery that's failing (as I suspect mine is after 5 years of every day use - had to jump start her after 2 weeks away from home at the start of August) affect the "lumpiness" of the engine after starting even if the battery started the engine successfully?
JOn
Re: Lumpy starting
Posted: Sat Aug 29, 2009 12:48 pm
by sparkymik
Not sure on this have you go power on the plug rail and is the fuse ok hope this helps
Sparky
Re: Lumpy starting
Posted: Sat Aug 29, 2009 1:31 pm
by francophile1947
jonb wrote:Question: will a battery that's failing (as I suspect mine is after 5 years of every day use - had to jump start her after 2 weeks away from home at the start of August) affect the "lumpiness" of the engine after starting even if the battery started the engine successfully?
JOn
Can't see why it should affect the tickover. Could be a faulty glowplug, or try putting some injector cleaner in the fuel tank.
