Leisure Battery
Leisure Battery
I have recently bought my bongo. It has a leisure battery. However how do i switch it over for leisure use???
Re: Leisure Battery
Not enough information there
. Presumably you have a conversion. If so, what make is it and what type of control panel do you have?
Re: Leisure Battery
If it isn't already, it's probably not a leisure battery.clip77 wrote:I have recently bought my bongo. It has a leisure battery. However how do i switch it over for leisure use???
You may have two batteries, but the second one isn't necessarily a leisure battery, it may just be a a second engine battery as some Bongos from the northern islands of Japan were fitted with "winter packs" part of which was a second main battery.
