alarm for leaving lights on?
Posted: Wed Aug 12, 2009 2:03 pm
by Barley 1981
Is there an alarm available that beeps when you leave your lights on?
thanks!
Re: alarm for leaving lights on?
Posted: Wed Aug 12, 2009 2:05 pm
by westonwarrior
yes there is a bleeper that sounds if you leave the lights on and take the keys out built in.
does yours beep iff you open the door with your keys in?
Posted: Wed Aug 12, 2009 2:08 pm
by Barley 1981
will try it when the cuprit gets home from work shortly, thanks!
I have never done it obviously, (yet) hehe
Posted: Wed Aug 12, 2009 2:12 pm
by westonwarrior
most disable the beeper so if yours doesn't work check the connector behind the cover at the drivers right foot,
Blue connector disconnecting stops the beeps
Posted: Wed Aug 12, 2009 7:00 pm
by Barley 1981
Thanks Rob,
No it doesn't beep, can anyone tell me which wire to re-connect, there are lots and can't see an obvious one which is not connected....
thanks
Tanya
Posted: Wed Aug 12, 2009 7:48 pm
by westonwarrior
as there is now another thread running on this I will lock this one
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=33948
