electric sliding door
djvoodoopunk
Post by djvoodoopunk » Sat Jul 18, 2009 6:25 pm
my door never closes automatically, all the wiring seem to be in place and ok but it does not work,
anyone had the same issue?
daveblueozzie
Re: electric sliding door
Post by daveblueozzie » Sat Jul 18, 2009 6:52 pm
Not all sliding doors on bongo's close automatically. :?
and its only the last inch or so that the mechanism takes over to tighten the door shut .
might be worth checking fuse no 17 15amp ,you never know might be an easy fix. [-o<
Lost without my Bongo.
steviebongo
Post by steviebongo » Sat Jul 18, 2009 10:15 pm
mine was the same never worked since i bought it ,striped of the door panel just to make sure it had it in the first place which it did, i used a whole can of spray lube into the latch area into both sides and after some tooing and frooing with the door and it eventually started to work. good luck.
cheers stevie
moots'r'us
Post by moots'r'us » Mon Jul 20, 2009 9:41 am
My slider stopped working a few weeks ago. After a bit of investigation i found the contacts on the door and pillar had become dirty (The ones that move in and out like trumpet keys!). Gave 'em a clean up with a bit of garryflex and bingo, working like a new one! :D
Might be worth a try.
Marcus Beechcroft
Post by Marcus Beechcroft » Wed Jul 22, 2009 10:57 pm
This is interesting - on my 96 Freda 2 of the spring-loaded "organ stops" on the body are fixed I wasn't sure if they did anything but would like to know if they should be spring loaded like the others? If they are I'll try to persuade them to work again!
Post by Simon Jones » Wed Jul 22, 2009 11:17 pm
A couple of them don't move. I think they might be fixed to detect when it gets to the end location.
Post by Bob » Thu Jul 23, 2009 12:26 am
My view is it's nothing but a pain, just draws from your battery every time you close it.
I honestly think you're better off just closing it manualy, no down side to that.
Gaza69
Post by Gaza69 » Thu Jul 23, 2009 12:31 pm
Bob wrote:My view is it's nothing but a pain, just draws from your battery every time you close it.
yeah but its cool to show off that little nugget to a VW neighbour on site. Their face is a picture when they see my lazy man door. lol
Post by Simon Jones » Thu Jul 23, 2009 12:37 pm
I think the Honda StepWagon has a fully electric door so you only have to push the handle & it opens all the way up.
Gaza69
Post by Gaza69 » Thu Jul 23, 2009 12:46 pm
Simon Jones wrote:I think the Honda StepWagon has a fully electric door so you only have to push the handle & it opens all the way up.
ooo, could we modify for a bongo you think? now thats truly the lazy many door. i dont care about battery drain, il fit another in the back for that. lmao :lol:
cheffy34
Post by cheffy34 » Thu Jul 23, 2009 10:55 pm
Ive seen a largo with a comlete remote door, super 8) never have to touch the handle again, defo an add on extra from japan the wiring was a shambles :wink: as to door not working it was the contacts on mine just dirty :wink:
dar
