Page 1 of 2
Central Locking Key Remote
Posted: Fri Jul 17, 2009 11:30 pm
by MintyMat
Hi, I've central locking and a remote key fob but it's starting to play up. The "unlock" button always works but the "lock" hardly ever does. Can I get a replacement remote cheaply or do I need to get the whole system rewired? Any advice/experience appreciated.
Re: Central Locking Key Remote
Posted: Fri Jul 17, 2009 11:32 pm
by Doone
I'm probably asking the obvious, but have you tried a new battery?
Posted: Fri Jul 17, 2009 11:38 pm
by MintyMat
Sorry, should have said, yes - I've replaced the battery. Problem is the same.
Posted: Fri Jul 17, 2009 11:40 pm
by jumper
Have you tried that stunt they showed, i think it was on top gear , a few years ago where you get your central locking key and walk away from your car untill it wont operate the locks because its out of range, then put the key against your head, point at the car and it will operate the locks. it actually works :lol: :lol:
Posted: Fri Jul 17, 2009 11:41 pm
by Doone
THIS link may help.
Posted: Fri Jul 17, 2009 11:42 pm
by MintyMat
Sounds fun, but I will probably only be able to unlock the car as however close I put the remote when locking it rarely locks.
Posted: Fri Jul 17, 2009 11:43 pm
by MintyMat
Doone wrote:THIS link may help.
Looks useful, but does it explain why unlocking always works and locking rarely?
Posted: Fri Jul 17, 2009 11:50 pm
by Doone
From reading it, I got the impression that faults can be due to either the remote locking sensor (and it tells you where it is so you can check it yourself) or the key fob.
Posted: Sat Jul 18, 2009 12:16 am
by miker
:lol: #-o Doone, you can lead a horse to water.......
Posted: Sat Jul 18, 2009 7:56 am
by MintyMat
Doone wrote:From reading it, I got the impression that faults can be due to either the remote locking sensor (and it tells you where it is so you can check it yourself) or the key fob.
Thanks. I'll have a look inside the driver's door panel and check the wiring. I always thought the little sensor near the windscreen on the driver's side of the dashboard was the door sensor - I wander what that's for?!
Posted: Thu Jul 30, 2009 7:53 pm
by missfixit70
Posted: Thu Jul 30, 2009 8:03 pm
by daveblueozzie
Probably not related to any problems in the earlier posts, but been having remote locking problems myself, it will lock the drivers door but not any other, been like this a couple of weeks, i have found the answer but it cost me £80. :shock:
It turned out my leisure battery was duff and not holding a charge, new leisure battery (hence the £80) and all is working as it should. :D
Happy, but a bit short in the wallet now. #-o
Posted: Thu Jul 30, 2009 8:07 pm
by missfixit70
Good point Dave, that was the first thing that started playing up when I had alternator/LB problems.
Posted: Thu Jul 30, 2009 8:08 pm
by Scott
In what year did they start fitting remote central locking into the Bongo's/Freda's, does anyone know ?
Posted: Thu Jul 30, 2009 8:13 pm
by daveblueozzie
csmcqueen wrote:In what year did they start fitting remote central locking into the Bongo's/Freda's, does anyone know ?
mine was an after market central locking with the alarm.
