Squeaking from Turbo is driving me mad!!!!!!!
the guvnor
Post by the guvnor » Thu Jul 16, 2009 7:45 pm
Not sure what is happening with this but it is drivin me mad !!!
When i pull away it gives a loud squealing sound on acceleration, then after about 2500 revs it is fine....as if belts were worn.....so changed drive and aircon belts and still noise is there !!
After a closer listen it seems to be from the turbo.......although after inspecting the turbo it seems to be ok ( no excesive movement from the internal turbo fan ).
Drive well, runs well, ticks over well everything is good apart from that bloody noise !!! :evil:
Anyone had this prob and how did you sort it ?????
thanks
kev
waycar8
Re: Squeaking from Turbo is driving me mad!!!!!!!
Post by waycar8 » Thu Jul 16, 2009 7:49 pm
might be a manifold stud thats sheared but by the sound of it the turbo is FUBAR.
miker
Post by miker » Thu Jul 16, 2009 7:57 pm
Agreed, probably a sheared manifold stud....if you drive gently do you still get the squeal?
the guvnor
Post by the guvnor » Thu Jul 16, 2009 8:01 pm
nope! if i pull away very slowly it doesnt sqeal until i start to accelerate harder!
miker
Post by miker » Thu Jul 16, 2009 8:08 pm
Not saying yours is def' the same problem but I had a very similar problem and it was a sheared stud, have a look at the passenger side of the engine, normally the front ones go. But before replacing the stud, get a 'proper' engineer to sort the manifold as it probably has warped it will need skimming flat....if you don't get it skimmed it will pop the stud again sooner rather than later.
mister munkey
Post by mister munkey » Thu Jul 16, 2009 8:28 pm
Strangely, I was at Waycars an hour ago when you posted this, popped by to get his ear on an annoying noise that has gradually manifested itself over the last few weeks. It sounds exactly like a slipping belt but only comes in between 1500/2500 revs & all belts appear to be okay.
General consenus seems to be the turbo has blown a bearing. This also backs up the increase in oil consumption over the last few months & billowing smoke when gunning it up hills.
My money is on you & me having the same problem. Luckily, I have a spare turbo (courtesy of Wayne - again) & will get it sorted over the weekend.
I'll keep you posted as to how I get on.
8)
Post by mikeonb4c » Thu Jul 16, 2009 8:56 pm
mister munkey wrote:Strangely, I was at Waycars an hour ago when you posted this, popped by to get his ear on an annoying noise that has gradually manifested itself over the last few weeks. It sounds exactly like a slipping belt but only comes in between 1500/2500 revs & all belts appear to be okay.
8)
Yrs sincerely
Smug-munkey :lol: :lol: :lol:
mister munkey
Post by mister munkey » Thu Jul 16, 2009 9:16 pm
mikeonb4c wrote: Yrs sincerely
I picked up a spare turbo a while back when it seemed that getting through a litre of oil every thousand miles may have been a turbo problem.
At this time it looks like that was a wise move.
No smugness, just forethought.
Post by Doone » Thu Jul 16, 2009 10:23 pm
Not sure what is happening with this but it is drivin me mad !!! When i pull away it gives a loud squealing sound on acceleration, then after about 2500 revs it is fine....as if belts were worn.....so changed drive and aircon belts and still noise is there !!
Hello 'The guvnor'... a forum 'search' will reveal that squeals have generally been found to be caused by a snapped manifold stud, slipping/worn belts, stuck 'cold climate' exhaust valve, exhaust manifold gasket, damaged exhaust baffle, a pinprick hole in a hose, or a turbo problem.
You've only had the bongo for 5 days, if you bought it from a dealer take it back and ask them to fix it. :)
mister munkey
Post by mister munkey » Thu Jul 16, 2009 11:00 pm
Doone wrote:A forum 'search' will reveal that squeals have generally been found to be caused by a snapped manifold stud, slipping/worn belts, stuck 'cold climate' exhaust valve, damaged exhaust baffle or turbo problem. You've only had the bongo for 5 days, if you bought it from a dealer take it back and ask them to fix it. :)
Fair call, there could well be many causes but - in my case, No 1 stud is still solid, (I've heard the famous snapped stud sound before on z00nons, mines not as loud) all belts are tight & true. winter pack switch is disabled, not to mention my s/s exhaust has an amplifier as opposed to a baffle & has been on for nearly a year without previous hassle.
The noise is coming directly from the turbo & getting worse by the day.
I'll get the turbo changed & see if things improve.
Watch this space.
Post by mikeonb4c » Fri Jul 17, 2009 12:07 am
Only joshing MM. I have Harrys old alternator so I can feel smug when the moment arrives :lol:
the guvnor
Post by the guvnor » Fri Jul 17, 2009 8:51 pm
Well thankfully it isnt the turbo :P
But it is a sheared manifold bolt, well 2 to be exact ! :x
As for taking it back to the dealer I dont really think i will bother. Tbh I am going to france next week and I would rather be sure the job is done properly and not bodged ! Peace of mind and all that :P
Thanks very much for the help guys.
Kev
Post by Doone » Fri Jul 17, 2009 11:53 pm
Sheared manifold stud, I reckon that's the commonest cause of bongo squeals. Luckily you don't have the same problem as mr munkey! 8)
mister munkey
Post by mister munkey » Mon Jul 20, 2009 6:08 pm
mister munkey wrote: My money is on you & me having the same problem. Luckily, I have a spare turbo (courtesy of Wayne - again) & will get it sorted over the weekend.
8)
Stand By Your Beds!
Turbo checks out as okay.
Its the exhaust manifold gasket on mine.
Post by Doone » Tue Jul 21, 2009 12:01 pm
Good one, I've added it to the list. :)
