tyre question
Posted: Fri Jun 26, 2009 11:16 pm
dont know much about wheels and tyres ,
but can you put std tyres on rx8 alloys ?
just thinking about saving money on tyres
If you mean std size tyres off steel wheels, no.BrixhamBongo wrote:dont know much about wheels and tyres ,but can you put std tyres on rx8 alloys ?
Well the answer is still no because if you don't fit low profile tyres to bigger rims (such as the RX8s) you will increase the diameter of the whole wheel (rim & tyre) and that will raise your gearing.BrixhamBongo wrote:well i kind of meant not low profiles
I know where you're coming from.. I didn't want low profile tyres on my 17" wheels and fitted 225/55/17s. They work great. The gearing business doesn't seem to have been an issue and I think that the autobox will simply shift down to match engine revs to load. It also has S and L settings as well as D which ought to cover all the pitches. Deeper profile tyres stop the ride from getting too harsh which is why I wanted them. the RX8s are 18" aren't they? Maybe see what is out there that will go on an 18" wheel. One thing I do know: if the overall diameter on the front gets too big the wheels will foul the front bumper stays (look inside wheel arch at front to see these) when turning. The Russian bongo peeps sorted this by cutting off the stays, with no ill effect they said (and they seem to know their stuff with Bongos)BrixhamBongo wrote:well i kind of meant not low profiles
