what tick over should it be on a 2.5d auto?
Posted: Thu Jun 25, 2009 1:58 pm
by chipvan
noticed it quite low and a little shakey at the lights its well below 1000 revs.
also If it needs changing where do i tweek it up
regards jez
Re: what tick over should it be on a 2.5d auto?
Posted: Thu Jun 25, 2009 2:02 pm
chipvan wrote:noticed it quite low and a little shakey at the lights its well below 1000 revs.
regards jez
Mine ticks over quite low (750rpm according to gauge) and you feel the vibrations from the diesel in a way you never would with a modern petrol engine. But its not unpleasant to me and I've come to love it and now just see it as part of the character of the Bongo. Once on the move, it disappears. I suspect some Bongos are smoother/quieter than mine (no idea why) but I'm happy with the 'Yorkie Bar Factor'.
Posted: Thu Jun 25, 2009 2:05 pm
by chipvan
ahh i see think thats about what ours is ,hang on i will go and fire er up...
Posted: Thu Jun 25, 2009 2:06 pm
by mikexgough
mine 750 rpm like mike's
Posted: Thu Jun 25, 2009 2:08 pm
by chipvan
yer its one section down from 1000 if that makes sence(the line below 1000)
so it sounds like its ok?
Posted: Thu Jun 25, 2009 2:19 pm
chipvan wrote:yer its one section down from 1000 if that makes sence(the line below 1000)
I think so. Its a little slower when stopped with autobox in 'D' than when in 'N', so you can ease things a bit if stationary for some time by putting car in to 'N' (keep footbrake on while moving from N to D to avoid a clunk in the transmission). Also, putting aricon on causes revs to drop as engine works harder. However, a sensor should raise the tickover back to where it should be when you do that although I've heard of some not doing it due to faulty sensor.
There is a throttle lever end stop adjustor screw I believe so you could choose to raise tickover that way, but honestly I think yours is pretty normal and its just a question of getting used to it, which I found you do and really start to quite like as part of the character of a diesel Bongo. My Toyota petrols often ended up with low tickovers that didn't feel good, but the Bongo tickover always feels like a healthy heartbeat. . At the otehr end of the scale, I find the Bongo diesel feels lovely, with bags of torque and doesnt make an intrusive noise (unlike my Spacewagon used to do) when working between 40-65mph (which is typical speed when the Bongo is where it belongs - on the open road).
Posted: Thu Jun 25, 2009 3:30 pm
by helen&tony
Mine gets a bit lumpy and 'orrible in the warm weather when the aircon. is on full blast, but when it runs at two divisions (so to speak, plus a little bit
all is cool
...that's around 700/750...the 2 divisions is theoretically660 , if the reverend counter is accurate...all those little busy vicars
Posted: Thu Jun 25, 2009 8:00 pm
by chipvan
Great thanks again guys
think i will leave it alone!
yep i love the power of the bongo it pulls like a train
Posted: Thu Jun 25, 2009 8:05 pm
by missfixit70
Try switching your aircon on & off, do the revs go up with the aircon on, or do they go down?
When the engine is cold, does it tick over higher for the first few minutes (ac off)?
Could be one or both of the vacuum solenoids on the forward end of the head under the drivers seat fubar, not a big issue, reasonably easily sorted.
Posted: Thu Jun 25, 2009 8:24 pm
by chipvan
Thanks kirsty
From cold with the aircon on the revs drop a little and when turned off the air con the revs went back up
will try it also when warming up 2mrw
Posted: Thu Jun 25, 2009 8:49 pm
by dreamwarrioruk
have a look at the vac pipe to the right, drivers side just above the glowplugs, the left ones for the egr valve and the right one controls the revs when you put on the air con (so they dont drop)
Posted: Thu Jun 25, 2009 9:39 pm
by missfixit70
What Mike said, could also be the solenoid itself is fubar, mine was, a visit to weymouth may be in order
Posted: Thu Jun 25, 2009 10:31 pm
by The Great Pretender
regards jez
Looped return? Air in system?
Posted: Fri Jun 26, 2009 10:27 am
by chipvan
Thanks guys, kirsty may have to head over your way will have anothe poke arround!
The great p,not done the veg conversion yet so its standard,but your right you can get air probs when looping return
