EGR system.
Posted: Thu May 21, 2009 6:33 pm
Hi everybody.
I have a new shape bongo 2.5 diesel V reg 1999.
After hours of fault finding I have found the EGR position sensor is faulty causing the glowplug light to flash and reduce power via the turbo wastegate.
I have tried blanking off the system but due to the elctronic sensor fault it still reduces power.
My question is: Is there anyway of fooling the ECU into thinking the egr position sensor is working and blanking of the egr system or do I have to find a new sensor.
The problem with the sensor is it should have a resistence of 4.5-5.5kh but is reading 8-9kh.
Any advice would be much appreciated as we're hoping to go away at the begining of June.
Thank you.
Ian.
Thank you.
Ian.
