Third rear brake light
espo2
Post by espo2 » Sat May 02, 2009 1:28 pm
Hi, I am fitting a third brake light to the top of my rear window on a Ford Freda and wonder if anyone can tell me the best or easiest point at which to hook up to the existing circuit??
With thanks,
espo2
Re: Third rear brake light
Post by francophile1947 » Sat May 02, 2009 3:58 pm
Welcome to the forum :D
Don't know if there's a loom in the tailgate as spoilers have a brake light :? Otherwise you'll have to tap into the rear lamp cluster.
Have a read of this http://www.igmaynard.co.uk/bongo/forum/ ... =42&t=9285 - local help is often available if we know where you are 8)
Post by Doone » Sat May 02, 2009 4:06 pm
Does this link help?
waycar8
Post by waycar8 » Sat May 02, 2009 5:21 pm
Hi, firstly do you have a rear spoiler with brakelight? if so then tap in to that, by taking off the rear spoiler and the wires are conected inside the top of the door by a conector block that branches off to the rear light clusters.
If you dont try striping the top rear drivers side plastic trim, the one at the very back where the rear tailgate buts up against when its shut. there might be the conector block already there that normally branches off to the rear spoiler for the light.
