oil leak rear axle n/s
Posted: Mon Apr 13, 2009 10:40 am
by Bulwell Bongoleers
Hi All
just having a look round under the bongo this morning and saw this oil leak. :shock:
It looks like its leaking from between the rear axle and the brake back plate.
Is there a seal between these? and is it an easy job to replace?
This is a 4wd Bongo don't know if this makes a differance?
Thanks Andy
Re: oil leak rear axle n/s
Posted: Mon Apr 13, 2009 12:08 pm
by hogggman
c`mon guys,someone must have had a similar problem
Posted: Mon Apr 13, 2009 3:43 pm
by francophile1947
hogggman wrote:c`mon guys,someone must have had a similar problem
No - but I would think that there has to be a seal (has been on every other car I've had with a back axle). Don't know if it's easy to replace or not :? - some needed a hub puller to get the hub off and access the seal.
Posted: Mon Apr 13, 2009 6:16 pm
by hogggman
just bumping this back up to the top :D
anyone had any ideas yet?
jamie
Posted: Mon Apr 13, 2009 6:37 pm
by mikexgough
This should help - http://www.lushprojects.com/bongopartsm ... mgno=.html
hopefully.........
Posted: Mon Apr 13, 2009 8:16 pm
by hogggman
that looks promising.........but maybe a big job to get into it :( hope not
Posted: Mon Apr 13, 2009 8:17 pm
by hogggman
Posted: Mon Apr 13, 2009 8:24 pm
by mikexgough
The 26-157 number matches.....for the outer seal - the 154 maybe replaced by the 150....
Posted: Wed Apr 15, 2009 10:45 pm
by Trouble at t'Mill
Pretty sure I've seen a thread on here showing this job complete with groovy pictures?
