Bongo starter battery
Posted: Fri Apr 03, 2009 5:00 pm
Decided to replace my main starter battery before it let me down at an inconvenient time or place. After overnight charging it had struggled to keep its charge. It would just about start the engine but seemed embarrassed to be asked! I searched the forum for information or recommendation on starter batteries but all I could really find was lots on leisure batteries and how to fit.
So I decided I'd have to start from scratch. I knew it was a fairly large sized battery and with a rating of at least 95Ah.
The existing battery was a Panasonic SR95D31L and looked as if it was the original as fitted by the manufacturer. I measured this battery and looked around the internet for a suitable replacement. It seemed to me that this power of battery in the case size required was not readily available. Halfords had nothing like it - either the size was too big or the power too small. It didn't help that a Bongo was not on their lists of vehicles.
To cut a long story short I eventually found a Bosch battery on ebay which seemed to fit the bill. (hawk-asg (9880) power seller, feedback 99.7 positive) The specification was as follows:
249/335 BOSCH SILVER S4028, CAR BATTERY 95ah, COLD CRANKING AMPS 830 SAE.
DIMENSIONS 306 L x 173 W x 225 H, (Total height to top of terminals). Also the positioning of the + and - terminals was perfect.
Delivery was next day if you ordered before noon. So very pleased and have now fitted it. Photos below:
Battery tray before fitting
Position of terminals
Battery model etc.
I'm posting this in case others have found a problem sourcing a main battery!
Battery model etc.
