Suspension knocks
Posted: Thu Apr 02, 2009 3:42 pm
by vanman
Afternoon every one, my N reg Std 4x4 auto Bongo has developed a suspension knock on uneven roads (every road bar moterways) both to the front & rear, Suspension brushes? or?
Also if i've a full load, 8 persons, the rear suspension bottoms out on some bumps even at 30mph. Are my shocks buggered. It dosent rock if pushed down on each corner..
Would welcome any comment.
Thanks.
Vanman
Re: Suspension knocks
Posted: Thu Apr 02, 2009 3:46 pm
by brorabongo
Suspension Knocks could well be your bushes and or their brackets, but most likely to be Drop Links. Sorry I do not know about the shockers.
by scanner
If you do a search on "suspension knocks" or "Drop links" you will find a lot of information on the subject.
Posted: Thu Apr 02, 2009 4:02 pm
by brorabongo
I've cheated for you Vanman.....
http://www.igmaynard.co.uk/bongo/forum/ ... ++%2Blinks++
I just clicked on Search ( just below adverts at top of screen) then entered.....
drop AND links
Posted: Thu Apr 02, 2009 4:32 pm
You have knackered droplinks and/or antiroll bar bushes by the sound of it. Cheap, simple and very effective to fix.
Bongos do tend to bottom out on heavy load and through the right rid at the right speed. Annoying but usually avoidable. SOme have fitted Airlift 1000 spring assiistors to stop it - don't recommend the other type of spring stiffener/assister though as it increases local stresses in the spring causing premature failure.
Posted: Thu Apr 02, 2009 5:10 pm
by Dabs
If its at the front it could also be the balljoints!!
I had the droplinks changed (still had a knock) then thought it was the bushes,had it looked closely at rather than an "own" diagnosis to find it was a balljoint at fault,had it changed and its like driving a new Bongo no more knocking and crunching!! Sorted!!! :P
Dabs
Posted: Thu Apr 02, 2009 5:12 pm
Dabs wrote:If its at the front it could also be the balljoints!!
Dabs
Just checked, mine are at the front but I can't feel any joints :lol:
Posted: Thu Apr 02, 2009 5:19 pm
by Dabs
Dabs
Ooooooooooh matron!!!!!! :lol: :lol: :lol: :lol: :lol:
Dabs :P
Posted: Thu Apr 02, 2009 5:30 pm
by scanner
Dabs wrote:
Dabs
Dabs :P
Trust Mike to talk a load of b*******s
