Page 1 of 2
SCREECHING NOISE WHEN TURNING RIGHT.
Posted: Thu Apr 02, 2009 8:47 am
by gavin
Monty has developed a screeching noise when turning right only and only when moving, sounds like it is coming from the drivers front corner. Doesn't happen when stationary. It does not sound like a belt slipping.
Any ideas?
Gavin
Re: SCREECHING NOISE WHEN TURNING RIGHT.
Posted: Thu Apr 02, 2009 9:16 am
by Dolly1
Hi Gavin,
Are you 4wd if so sounds like a CV coupling is on the way out.
Posted: Thu Apr 02, 2009 9:22 am
by gavin
I do have 4wd.
Is it expensive?
Posted: Thu Apr 02, 2009 9:26 am
by Dolly1
No idea,
No doubt someone has all the info:and will be in touch with you.
I would check out the other wheels whilst you are at it
Posted: Thu Apr 02, 2009 9:28 am
by gavin
Thanks for your speedy reply
Posted: Thu Apr 02, 2009 8:12 pm
by steviebongo
i would check ure cv boot security?
cheer stevie
Posted: Thu Apr 02, 2009 8:22 pm
by francophile1947
CV joints don't normally screech - they tend to make a knocking/clicking noise. I'd be more inclined to check your brakes for something, like a bit of grit, bedded into a pad. Does it stop if you apply the brakes?
Posted: Thu Apr 02, 2009 8:25 pm
by steviebongo
do bongo's have screechers on the pads as a way of telling u they are worn I no some other cars use this ?
cheers stevie.
Posted: Fri Apr 03, 2009 8:30 am
by gavin
Thanks for all your replies. Will have a look at the weekend
Posted: Fri Apr 03, 2009 9:17 am
by Hippotastic
I posted the same problem a week ago.
It turned out that the bottle that holds the steering fluid was empty. The noise is the power steering looking for oil. Same for me, only on turning right. The bottle is under the drivers seat, and it is hard to miss. Suprising as I had been in there many times and never noticed it!
I got my MOT last week, thinking I had a CV joint problem, it passed and I have a leak in my steering system somewhere, and adding Dextron 3 oil to the steering fluid bottle should fix the problem in the short term. Long term I guess we got to find out where it is leaking from.
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=29760
Posted: Sat Apr 04, 2009 11:36 am
by gavin
Thanks for the tip, I will have a look this weekend when I have finished work.
Gavin
Posted: Wed Apr 15, 2009 8:28 am
by gavin
TOOK MONTY BACK TO 321 AWAY WHERE HE CAME FROM ON BANK HOLIDAY FRIDAY. EXCELLENT SERVICE AGAIN, NOTHING WAS TOO MUCH TROUBLE AND THE MECHANIC CAME INTO WORK ON THE BANK HOLIDAY!
FIRST THEY TIGHTENED THE POWER STEERING BELT BUT THAT DIDN'T DO IT, NEXT THEY CHECKED THE BUSHES, THEY WERE FINE (ALMOST NEW). THE PROBLEM WAS WITH THE BRAKES, WHICH WERE STRIPPED DOWN, CLEANED AND REASSEMBLED AND THAT CURED THE PROBLEM. YIPPEE
Posted: Wed Apr 15, 2009 9:19 am
gavin wrote:TOOK MONTY BACK TO 321 AWAY WHERE HE CAME FROM ON BANK HOLIDAY FRIDAY. EXCELLENT SERVICE AGAIN, NOTHING WAS TOO MUCH TROUBLE AND THE MECHANIC CAME INTO WORK ON THE BANK HOLIDAY!
Result
Well done 321
Brakes huh - how strange. Was it a stone or something that had got caught in them?
Posted: Wed Apr 15, 2009 11:59 am
by francophile1947
mikeonb4c wrote:Brakes huh - how strange. Was it a stone or something that had got caught in them?
Not at all strange Mike - see my post above
Posted: Wed Apr 15, 2009 3:36 pm
by gavin
THERE WAS NOTHING CAUGHT AS FAR AS I COULD SEE.
LOOKING FORWARD TO OUR FIRST OVERNIGHTER THIS WEEKEND
