towbar electrics
Posted: Sat Mar 21, 2009 10:08 am
by tay
hi guys,would i be right in thinking that a standard single electrics will suffice on the bongo,without the need for extra relays as used on vehicles with a multiplexed or can-bus type wiring.cheers tay.
Re: towbar electrics
Posted: Sat Mar 21, 2009 10:56 am
by patnben
The extra "S" type socket is only usefull if you tow a
caravan and need to keep the fridge topped up. it
also provides reversing lights and a supply to charge
the caravan leisure battery.
The standard "N" type socket is all you need otherwise
and much simpler to fit and wire.
Posted: Sat Mar 21, 2009 12:06 pm
by tay
thanks for that,a simple single electrics is all i need.cheers tay
