Passenger Side window help.
Posted: Sat Mar 14, 2009 10:08 pm
by bongobong
The passenger side window on my bongo has stopped working. Everything else works. Any ideas what could be the problem
Re: Passenger Side window help.
Posted: Sat Mar 14, 2009 10:14 pm
by Jolly Rogers
It could be a few things
1) Hold switch on the Drivers switch on
2) Broken wire between the door
3) Dirty connections in switch
4) Broken switch
Posted: Sat Mar 14, 2009 10:16 pm
by scanner
Broken wire in the loom where it goes from bodyshell to door.
Common failure due to the tight cable tie thing that holds the loom to the hinge creasing the wires and they eventually break..
Posted: Sat Mar 14, 2009 10:17 pm
by bongobong
Thanks for your reply,
I know its not the hold switch. Not hot on electrics, what the best way to go about tracing the fault?
Posted: Sat Mar 14, 2009 10:50 pm
by steviebongo
hi there see if there is any power at the n/s switch or earth for that matter?
Posted: Sun Mar 15, 2009 1:15 am
by jaylee
Yep, try the passenger switch.. If that don't work either.
The driver door looms the best bet!!
Make sure to check the wire under the grommet cowling thing in the door & body panel as well as where the loom bends to the door hinge clip..
Posted: Sun Mar 15, 2009 8:35 am
by wonkanoby
wobble the loom around by drivers door
whilst some one holds the switch up is my bet to
