Central locking query
Posted: Thu Mar 12, 2009 3:56 pm
by helen&tony
Does anyone know the colour of the door wire for the central locking...mine has stopped working...I've checked the fuse, and I suspect a broken wire in the bundle coming from the drivers door...also the wing mirror...I know that IS a broken wire, as a quick wiggle of the bundle gets it working again
Any help appreciated
Re: Central locking query
Posted: Fri Mar 13, 2009 2:50 pm
by bigdaddycain
Somebody must know!
Posted: Fri Mar 13, 2009 3:17 pm
by Colin H F
Hi helen & Tony, if you check my posts on central locking you will find I have been doing a lot of work sorting mine ,I have a `99 model and I dont know if things change with different models but mine is fuse number 1 , 10amp and the supply wire to the door is purple&blue and the two return signal wires are yellow&red and white&black good luck Colin newbie
Posted: Fri Mar 13, 2009 3:19 pm
by bigdaddycain
Good man newbie!
Let's hope they didn't change the colour of the wire...
Posted: Fri Mar 13, 2009 3:59 pm
by helen&tony
I'll check tomorrow....the fuse is No.4 ..@ 30 amps on mine, but that's O.K. I'll have a look at the door wire, and if not, it's the door card off. The remote works the driver's door popple, so it's either a wire, or the switch on the driver's door keylock....more later when I've found it....
Posted: Sun Mar 15, 2009 10:13 am
by helen&tony
Abra Cadabra....
Now, folks, if you utter these words as you operate the faulty central locking....the darned thing starts working again. Now I am sure the fault was in the driver's door wire, so....I'm thinking that as the door wires are a common fault, if we could get the door grommets and suitable plugs, it may be worth while getting a batch of replacement loom sections made up. No doubt I can find someone over here to make them cheaply, and send them en-masse to the UK via courier if people are interested
