Newbie Question - Gearbox Oil / Power Steering Fluid
Posted: Fri Mar 06, 2009 7:28 pm
Hello Folks, Just did a quick check of the Gearbox oil / Power steering Fluid and the power steering fluid is well below the minimum and the gearbox oil is at the minimum mark.
Given that I checked the levels cold I assume that, since the gearbox oil is probably all sitting in the sump, that I'll have even less when I check it once it's warmed up!
I believe I need a D3 (DIII?) oil for the gearbox, but what do I need for the power steering? I see that Halfords do a combo DIII Gearbox/Powersteering Oil so I assume its pretty much the same stuff? The guy in Halfords wasn't sure but seemed to think it needs Ford-compatible oil. Apparently if I go back tomorrow there is a guy works there who has a Bongo - wahey!!
Anyway am I right on the gearbox oil and do I need something specific for the power steering or just the same stuff.
(Oops - forgot to mention it's a 2.5Dti Auto)
Thanks in advance for any help.
Iain
Iain
