FRONT FOGLAMPS
Posted: Thu Mar 05, 2009 7:58 pm
by brian-willoughby
I have just acquired a very nice Bongo.
It was imported with Front Fog lamps fitted, but no switch fitted on the dashboard.
Can any fellow owner tell me how to get them working?
Also what does the T.V Screen fitted above the radio do?
Reards Brian and Joan.
Re: FRONT FOGLAMPS
Posted: Thu Mar 05, 2009 8:06 pm
by waycar8
hi Brian, welcome to the forum mate, is the screen fitted in Japan or here on arrival?, if its one from Japan which is probably the case, its no good, the tvs in Japan are different to ours so they are worthless. as for the front fog light switch?.........is there a hole in the dash where a switch was?
Re: FRONT FOGLAMPS
Posted: Thu Mar 05, 2009 8:27 pm
by aitch
Ditto above with regard to the screen but the fog/driving lights is a nother matter try and follow the wireing to trace where it is going and you might find it behind the dash and just needs a switch - mine is fitted with "set in the bumper" lights but I cannot trace the wire so if you have success let me know and good luck.
Re: FRONT FOGLAMPS
Posted: Thu Mar 05, 2009 8:32 pm
by waycar8
Have you tried to see if they come on with the high beam?, i have heard of a couple that have had them wired up to the main beam
, a bit pointless imo but hey each to their own
Re: FRONT FOGLAMPS
Posted: Thu Mar 05, 2009 8:36 pm
by francophile1947
Mine came on when I switched any lights on
Re: FRONT FOGLAMPS
Posted: Thu Mar 05, 2009 10:30 pm
by aitch
Lucky you John have been playing with my lights for two years and I have yet to get them on at all!!!!!!!!!!!!!!!!
Re: FRONT FOGLAMPS
Posted: Thu Mar 05, 2009 10:34 pm
by francophile1947
aitch wrote:Lucky you John have been playing with my lights for two years and I have yet to get them on at all!!!!!!!!!!!!!!!!
I disconnected them anyway, just in case an officer decided to nick me for illegal use - must get round to rewiring them sometime
Re: FRONT FOGLAMPS
Posted: Fri Mar 06, 2009 5:14 pm
by Doone
In this link, they discuss the option of wiring in a switch for the front fogs. There's a lot of additional info, so it should help.
Re: FRONT FOGLAMPS
Posted: Fri Mar 06, 2009 7:50 pm
by technophobe
I've got a switch for each pair.
Re: FRONT FOGLAMPS
Posted: Fri Mar 06, 2009 10:58 pm
by dandywarhol
Would some kind soul wiggle out their switch and see if it has 2 round black bulb holders in it - about 4m diameter on the left side.....................Thanks
Re: FRONT FOGLAMPS
Posted: Fri Mar 06, 2009 11:20 pm
by maxheadroom
Standard fitted one only has one bulb.
Re: FRONT FOGLAMPS
Posted: Sat Mar 07, 2009 1:29 am
by dandywarhol
maxheadroom wrote:Standard fitted one only has one bulb.
Thanks max - and where does the standard front foglamp warning light live?
I picked up a 2 bulb Mazda switch which I thought would be easy peasy fit but its got a weird circuitry involving a diode and seems to earth the warning light (in the switch) via the relay coil and earth
Re: FRONT FOGLAMPS
Posted: Sat Mar 07, 2009 10:16 am
by maxheadroom
dandywarhol wrote:maxheadroom wrote:Standard fitted one only has one bulb.
I too have a similar switch and have never managed to get it to work. Can't help with the wire at the moment but if I find out I will post.
