Can't get over 2k revs or 20mph plus smoke and chugging !!
Just recently increasing over 2-3 days I found my bongo dosent pick up revs..it will idle just fine and rev up to 2k but if you put your foot down a little more it'll just smoke chug and shake.
So when on the move I can only go about 20 mile per hour!!!!
Ive whacked a load of injector cleaner into the tank and directly into the fuel filter, i have also changed the fuel filter and checked the tank for debris....What now????? Help!!!!
- You've Been Bongod
Re: Can't get over 2k revs or 20mph plus smoke and chugging !!
somebody correct me if i am wrong BUT doesnt that sound like the egr valve might be sticking ?????
Wiskers have you check the air intake is clear and the air filter is ok. Could be not enough air getting through.
Manny
Manny
A Bongo by any other name would still drive as sweet.
Stand corrected CarlYou've Been Bongod wrote:somebody correct me if i am wrong BUT doesnt that sound like the egr valve might be sticking ?????
I don't think the egr would cause those symptoms, but the engine warming button, if it's got one, may be causing the problem, it does get knocked on inadvertantly, this closes a valve in the exhaust on the twin battery set up. Look down by your knee for a button with a pic of an engine on it. Sometimes the valve sticks closed.
Blocked banjo filter on fuel pump?
and/or blocked main fuel filter those are the exact symptoms.francophile1947 wrote:Blocked banjo filter on fuel pump?
You may have changed it "yesterday" but if it gets a load of kak through it that can be the result in less than 100 miles.
- haydn callow
Agreedfrancophile1947 wrote:Blocked banjo filter on fuel pump?
you have not put bio fuel in have you.
Thats what happened with mine after i did. cost £400 to sort
- brorabongo
Wiskers, these topics might help......
http://www.igmaynard.co.uk/bongo/forum/ ... ss#p268381
http://www.igmaynard.co.uk/bongo/forum/ ... bo#p152326
Good luck.
Good luck.
thanks, Im working my way through these posts today...
I have tried in vain in the past to locate the Banjo filter..I understand its on the fuel pump?? somewhere where the fule hose enters it, but where? and how many tiny tiny parts have i got to remove beofre I find it!!!!!
heres the fuel pump, where would it be located in relation to this diagram???
Undo the banjo connection on top of the pump, where the fuel goes in. There is a small gauze filter in the bottom of the hole. It's delicate, so I used a cotton bud to get it out.
thanks I'll take another look, If you're still online what is the banjo connection??? why so called?
Thanks for your reply
Just because of it's shape AFAIK
Undo the nut where the fuel goes in - filter is at bottom of hole
