Page 1 of 2
My bongo is making a hisssing type noise
Posted: Tue Mar 03, 2009 8:12 pm
by mblakeway
Hello all
I have noticed that when the turbo kicks in there is a hissing type noise. It seems like its coming from the front end of the van, almost sounds like air is escaping somewhere. I dont know if anyone has had this before. I find that when the turbo kicks in the noise starts then as the turbo eases back down the noise goes. As I mentioned its like a hissing sound, like air leaking from a tyre. Sounds silly but not sure how else to describe it.
Any help is always appreciated. Is there a garage that deals in imports in the stevenage area as I would like some work to be done on the van.
Many thanks
Mark
Re: My bongo is making a hisssing type noise
Posted: Tue Mar 03, 2009 8:14 pm
by bigdaddycain
It's just the sound of the turbo spooling up, add a K&N to make it louder!
Posted: Tue Mar 03, 2009 8:17 pm
by missfixit70
Check your seat clips are tightened down properly, may be time to "adjust" the bent spring section with a couple of hammer taps to tighten them up a bit
Worked wonders with mine.
Posted: Tue Mar 03, 2009 8:44 pm
by jaylee
I know it's been done before, but it's worth dragging out again..!
Posted: Tue Mar 03, 2009 9:18 pm
by bigdaddycain
Posted: Tue Mar 03, 2009 10:56 pm
by mblakeway
Thanks for the information, will look into the seat clips.
Just sounds a bit louder than a normal turbo spinning up. As I said, its a bit like air leaking out of a tyre.
Posted: Tue Mar 03, 2009 11:02 pm
by Jolly Rogers
You could always check your hoses. I had a similiar noise coming from my Bongo, it turned out to be a pinprick hole in one of my hoses.
Posted: Tue Mar 03, 2009 11:18 pm
by Regor
How about the snapped stud on the exhaust manifold syndrome
Unless you've driven round a snake park lately
Hope you find out soon
Posted: Tue Mar 03, 2009 11:51 pm
by cheffy34
bigdaddycain wrote:It's just the sound of the turbo spooling up, add a K&N to make it louder!
Trust you to like the turbo windup
that is the one thing my puppy is missing
suppose i will have to make do with the sound of 6 cylinders dancing
Dar
Posted: Wed Mar 04, 2009 12:01 am
by steviebongo
sounds like a possible leak on the boost side maybe an intercooler leak ,particuarly if it's when under load.
Posted: Wed Mar 04, 2009 12:08 am
by dandywarhol
I'm with stevie - check all hoseclips from the turbo to the intercooler and out the intercooler to the inlet manifold - it's a long and winding road......................
Posted: Wed Mar 04, 2009 12:09 am
by mblakeway
where is the intercooler?
I will have a look at the hoses and stuff tomorrow, could you give me some advice on where to start!
I have checked the exhaust manifold, all ok on that side of things. The head was replaced a few months ago and all the fixings were changed, still I checked them today.
Thank you all
Posted: Wed Mar 04, 2009 12:26 am
by dandywarhol
Intercooler behind the radiator - the 2 air ducts under the front bumper feed air to it.
Sounds like a loose clip to me - especially if the head was recently replaced - hope they haven't forgotten to tighten anything else
Posted: Wed Mar 04, 2009 12:55 am
by not so old
Sounds really daft,
but it couldnt be your roof seals are damaged. We had this hissing for a while which got louder the faster we went and eventually turned into a squealing noise, it was then I realised it was the roof and the nice folk on here helped me diagnose it. small holes in the rubber seal was the cause and easily fixed. Probably something more Technie, but thought I'd mention it anyway
Posted: Wed Mar 04, 2009 1:34 pm
by dom_e
I've read this thread with interest. We've got the same issue with ours - the hissing gets louder under load and is audable at about 65mph up a slight slope on a motorway for example. I'll also be checking hoses etc. soon!
I know our radiator was replaced by the last owner - any potential link? I have very limited knowledge on turbos, intercoolers etc, let along where they are on the Bongo
