Parts needed V6
Posted: Mon Feb 09, 2009 5:58 pm
Took the Freda to the garage today to have a £13 crank seal fitted which had a small leak. So while its stripped down Ive sourced some cam seals as well (£50). Because i didn't know how much oil had got onto the belts i decided to change these as well even though the timing belt is only twelve months old (£120).
Just got a phone call from the garage telling me i need a new left inlet cam pulley (anybody know where i can get one?) two teeth missing and cracked, surly the reputable Bongo dealer i bought it off would have noticed this when he did the pre-sale cam belt change and 50 point check or when it went back for new tappets under warranty three months later???? so now i also need to try and find rocker cover gaskets, inlet manifold gasket, water pump gasket (very small leak) and rocker cover washer/seals, all in all looks like its going to be an expensive £13 seal
