won't start !!!!
Posted: Sat Jan 17, 2009 2:09 pm
by GRAHAMPK
Help !!! anyone know what the small "fuse link" for the glow plugs connected to the positive terminal can be replaced with, is it a known part and if it is dead what caused it to go wrong is the relay playing up ? Mine wont start at the moment and this is all I can find wrong.Would a faulty relay cause it to "blow" ?
Re: won't start !!!!
Posted: Sat Jan 17, 2009 2:15 pm
by missfixit70
Posted: Mon Jan 19, 2009 8:00 pm
by teenmal
GRAHAMPK wrote:Help !!! anyone know what the small "fuse link" for the glow plugs connected to the positive terminal can be replaced with, is it a known part and if it is dead what caused it to go wrong is the relay playing up ? Mine wont start at the moment and this is all I can find wrong.Would a faulty relay cause it to "blow" ?
Hi Graham,if the fuseable link is blown,you might be able to replace it with a Wafer Fuse.
Its a while since I last used one,but if you Google Wafer Fuse you might get the info that you need.
Cheers Mal..
