Problem with willinton relay kit i think?
Posted: Fri Jan 16, 2009 2:35 pm
I think my leisure battery is not being charged.
I measured the LB voltage and got 8.5 volts so put it on charge using a optimate charger. left the battery on charge for a few days and and measured nearly 13 volts.
I put the battery back in the bongo and started the engine and got 14.2 volts across the main battery but only 12.8 volts across the LB, is this correct?
Also when i put the battery back I did not hear the relay switch, after a few days of using the van the relay started to switch but kept switching, this stop after a min or so. The problem is that the relay was still switching when i turned the bongo off.
Turn the ignition on and turned the radio off then turned the ignition off and the relay stopped switching.....
This may of happened before because when i left the bongo to have the diesel pump fixed the garage rung me to tell me the bongo was completely dead.
Any ideas to what wrong?
