Page 1 of 2
banjo filter needed quick.....
Posted: Tue Jan 13, 2009 9:35 pm
by bongomaan
I had to clean my banjo filter today and when i put it back in it flipped and went in upside down,trying to get it out i have damaged it and now need a new one so the million pound question is does anyone know where i can get a new one from (and a spring that i lost by coincidence in the spring ) any help would be gratefully received (as usual...) and what are the consequences of running without one.thanks in advance...neil...
Re: banjo filter needed quick.....
Posted: Tue Jan 13, 2009 10:43 pm
by Simon Jones
Not an expert, but I would have thought the main fuel filter would take care of most of the crud in the fuel. I've had a look on Bongobits.com, but they don't seem to list it. You could try taking it to a diesel injection specialist to find a close match. I managed to lose the spring on mine so just found a similar diameter one in the shed & cut it to length. It is only to hold it in place, so the dimensions are not too critical. Good luck with your search
Posted: Tue Jan 13, 2009 10:52 pm
by bongomaan
cheers simon i have enquired with a couple of people on ebay,didnt think of buying a similar replacement will try tomorrow....regards neil......
Posted: Tue Jan 13, 2009 10:54 pm
by missfixit70
Give Bellhill a shout, they may be able to sort you out with one from a breaking bongo.
Posted: Tue Jan 13, 2009 11:11 pm
by Harry
I lost the spring twelve months ago and decided not to replace the filter.
No probs to daye and VERY high milage.
H 8)
Posted: Tue Jan 13, 2009 11:17 pm
by bongomaan
WOT NO BANJO ?do you use veg oil H ?
Posted: Tue Jan 13, 2009 11:36 pm
by Harry
I was using up to 90% veg oil (pure rapeseed) in the summer but I'm back on 100% derv now due to it being cheaper than veg oil (after the VAT refund)
H 8)
Posted: Wed Jan 14, 2009 12:34 am
by dandywarhol
Its a Bosch pump so a Bosch agent should be able to sort you out - try Lawson Diesel in Edinburgh
Posted: Thu Jan 15, 2009 11:04 am
by parawaiting
according to the specialist who refubished my fuel injection pump its better not to have it as it will keep blocking up periodically, the fuel filter filters down to 5 microns anyway
Posted: Thu Jan 15, 2009 11:35 am
by mick
No filter on mine for about 2 years now. It runs fine.
Posted: Thu Jan 15, 2009 1:18 pm
by dandywarhol
parawaiting wrote:according to the specialist who refubished my fuel injection pump its better not to have it as it will keep blocking up periodically, the fuel filter filters down to 5 microns anyway
I think I'd rather clean out the filter than have the crap scoring my injection pump or injectors. :shock:
Posted: Thu Jan 15, 2009 1:21 pm
by scanner
Yep, if it isn't needed what does it block up with?
Posted: Thu Jan 15, 2009 1:30 pm
by francophile1947
Have to admit to being puzzled by the banjo filter :? How does a mesh strainer get blocked when it's after the much finer fuel filter?
Posted: Thu Jan 15, 2009 1:50 pm
by scanner
francophile1947 wrote:Have to admit to being puzzled by the banjo filter :? How does a mesh strainer get blocked when it's after the much finer fuel filter?
Me too - but if it does get blocked it must be stopping something that shouldn't be getting past it.
Must be moisture getting in through the pipes. :wink:
Posted: Thu Jan 15, 2009 2:08 pm
by francophile1947
scanner wrote:Must be moisture getting in through the pipes. :wink:
Or the seals :wink: :lol: :lol:
