intermitent rev counter blues.....
bongomaan
Post by bongomaan » Thu Jan 08, 2009 10:26 pm
got those old rev counter blues........ hi everyone,thought the old girl was behaving herself too well because i havent had to log in for a wile,but just to reassure me i am a bongo owner the glow plugs i put in in the spring are going and every now and again my rev counter stops and i get a fault code flashing,i"ve had the dash out and checked contacts but im starting to think tps sensor maybe.......any thoughts anyone ?...and by the way happy new year to you all and lets get that sun shining this summer........neil
You've Been Bongod
Re: intermitent rev counter blues.....
Post by You've Been Bongod » Thu Jan 08, 2009 10:29 pm
keep an eye on your speedo as mine did that a couple of years ago and had to have a new chip put in for speedo costs around £75
bongomaan
Post by bongomaan » Thu Jan 08, 2009 10:34 pm
as far as i know mr b its not chipped unless you mean the original factory chip ????
Post by missfixit70 » Thu Jan 08, 2009 10:36 pm
When my rev counter played up, speedo went iffy shortly after, then alternator went, be worth just checking it's chucking out full voltage.
Have you done the fault code thing to check what the code is? Check the factsheets for a how to.
You've Been Bongod
Post by You've Been Bongod » Thu Jan 08, 2009 10:41 pm
mine has the chip to convert it from kph to mph thats the chip that went on mine
bongomaan
Post by bongomaan » Thu Jan 08, 2009 10:44 pm
i hope its not the alternator,i had reason to go into a box/file type thing that i keep paperwork in the other day and the bit that keeps the bongo receipts in had exploded and whilst collating them i coudnt help counting some of them......scary.....im not moaning or ought but jesus.......all im saying is dont look people it will make yer eyes water.....
Post by Bob » Thu Jan 08, 2009 10:59 pm
Had that symptom twice on LDV engines. Altenator both times.
bongomaan
Post by bongomaan » Thu Jan 08, 2009 11:13 pm
i dont understand how the alternator and rev counter are related surely its a tps or electrical contact type thing,but im no expert also im 90% sure the spedo is not affected,i will check out the alt" output though,is it possibly the belts ?????
daveblueozzie
Post by daveblueozzie » Fri Jan 09, 2009 12:02 am
http://www.igmaynard.co.uk/bongo/forum/ ... &sk=t&sd=a
try this link dunno if it will help or if its the same problem as i had.
Lost without my Bongo.
dandywarhol
Post by dandywarhol » Fri Jan 09, 2009 12:05 am
Have a check at the wiring connectors going to the CENTRE coolant sensor on the head - it tells the ECU it's info. I found a bad connection on a friends bongo which caused the hold light to flash and the tachometer to drop.
bongomaan
Post by bongomaan » Fri Jan 09, 2009 12:10 am
thank you geniei (i believe thats the collective noun for lots of clever clogs ) makes sense to me,will check it out....
daveblueozzie
Post by daveblueozzie » Mon Jan 12, 2009 9:56 pm
bongomaan, Did you ever sort the problem with the rev counter ?
bongomaan
Post by bongomaan » Mon Jan 12, 2009 11:25 pm
not yet,family issues to be sorted last weekend but hopefully will fit new glow plugs and look at the rev counter next weekend,funny though since i put up that post no fault code.......but i think i also need to check out the rad fan sensor as advised by dandy warhol when i replaced my water pump ages ago,i recon by next xmas i"ll have a new van.will post results asap.....neil....
