Starter Motor Number
- dandywarhol
Could anyone tell me the make and number on a '96 diesel starter motor?
I can get a repair kit locally but need the motor number.
Thanks in advance
Alan
Thanks in advance
Alan
Re: Starter Motor Number
bongo bits have a new one for £183.31
http://www.bongobits.com/Main.asp?PageN ... roduct=288
- dandywarhol
I'm looking for just the make and number wayne - an overhaul kit will sort it, it's a worn contact problem, fixed for a helluva lot les than £183 . I can get the kit from my local factor but they need the original motor number.
Mazda part WL0118400 or Blueprint ADM51234.
- dandywarhol
Is that the number on the motor casing Ian?
That's the number on the box, and therefore on my database. Don't have one to hand I'm afraid.
Don't forget that there are two models of starter motor - the winter one is more powerful, but can be replaced with the single battery model.
- dandywarhol
I'll try the Mazda number with my factors tomorrow - I don't think it'll compute though - they want the original motor manufacturers number. Thanks for trying though
Any other actual numbers stamped on the casing or on a sticky label will be appreciated
From what I've read on here, Moonshine (Colins) tips on replacing parts in the starter motor is only valid for the motors on the non winter pack Bongos. The (more powerful) winter pack ones (for some reason I can't remember) are not amenable to the treatment
- dandywarhol
Non winter, southern climes starter motor I'm overhauling - any more mumbers greatfully appreciated
Ah! THought yours was a winter one from something you said on another thread recently, but then I am The One With The Addled Braindandywarhol wrote:Non winter, southern climes starter motor I'm overhauling - any more mumbers greatfully appreciated
- dandywarhol
OK gocha - no mine is non winter but I also look after a few other ones belonging to friends. One of these is a "semi winter" one - its got the cold climate heater air intake (probably the one you took to be mine on a previous thread) but it only has a single battery and no exhaust system warm up valve! funny things these Bongos................
- westonwarrior
I got the contacts and plunger from Southampton as mentioned on here a few times arrived next day.
just asked for contacts and they said Bongo
havent found 5 min to fit them yet will be a job over Christmas
hi Dandy,if you are just looking for a contact kit,E-Bay are doing them for £6.99 inc P&p.
Nippon Auto Parts,Item No 260327927.
Cheers Mal..
Cheers Mal..
- westonwarrior
260327927306
is the full code but it does not include the plunger like the one in Southampton does which may or may-not be needed
