Having replaced the six hoses that flippa sells top/bottom, rad. Top/bottom, engine. Hose over starter. Expansion/header tank to rad. I have also had the bleed hose replaced (thanks Haydn), I now have to replace the metal coolant pipe o/s. That's seven out the way.
Now the questions are peeps, whilst it is all apart:
Do I change any other hoses?
They all look ok
Which hose (this is a tuff one) do you think may go next?
This will be the 4th bleed/coolant change this year and I would like to try to knock it on the head this time as every time some thing is replaced a leak springs up elsewhere.
Thanks chums
