Electric Supercharger
Posted: Fri Nov 28, 2008 1:01 am
by Simon Jones
...or just a glorified hairdryer?
http://cgi.ebay.co.uk/Turbo-Supercharge ... 240%3A1318
The theory seems fine, but I'd be surprised if it made any difference on a diesel Bongo. Anyone fancy getting one to find out?
Re: Electric Supercharger
Posted: Fri Nov 28, 2008 1:04 am
by missfixit70
I'd have thought it'd be a bit pointless on a turbo diesel, may be useful to dry your hair when camping
Posted: Fri Nov 28, 2008 1:53 am
by scanner
Snake oil anyone?
Posted: Fri Nov 28, 2008 7:50 am
by moonshine
Bears an uncanny resemblence to a heater blower motor to me.
I doubt very much whether it would push any more air in than the existing turbo would anyway, and could possibly even restrict airflow to the engine.
Any experts out there care to comment?
Posted: Fri Nov 28, 2008 11:00 am
by Trouble at t'Mill
No idea if it works to any degree whatsoever, but it certainly wouldn't benefit an already-turbo'd engine.
Posted: Fri Nov 28, 2008 3:23 pm
by tricky
Trouble at t'Mill wrote:No idea if it works to any degree whatsoever, but it certainly wouldn't benefit an already-turbo'd engine.
Not strictly true. Superchargers and turbos have often been used together in the same application as SCs have a linear response at lower speeds, the output being directly proportional to engine speeds as they are directly coupled. Turbos windmill in the exhaust flow until the revs build and it starts to build up to increase inlet pressure. This process takes a finite time hence turbo lag. Thus in high performance applications an SC may be used to give instant response in the rev curve below peak torque output and a mechanical decoupling may be used when the TC takes over. Whether this would be wothwhile in a diesel Bongo is obviously debatable but the two boost methods are not mutually exclusive.
Posted: Fri Nov 28, 2008 4:10 pm
by scanner
tricky wrote:Trouble at t'Mill wrote:No idea if it works to any degree whatsoever, but it certainly wouldn't benefit an already-turbo'd engine.
But THAT is NOT a supercharger - if anything it is an electrically powered turbocharger as it is a centrifugal blower not a linear one.
Interesting that the pictures suggest it could be useful on a Bugatti Veyron.
I wonder what percentage power increase it gives on one of those?
Posted: Fri Nov 28, 2008 8:19 pm
Fair enough tricky.
I understand the differences and my comment was an 'overview'; whilst this device might make a 'noticeable' difference to a normally-aspirated engine, I don't believe for a second it would make any difference to ANY already-turbocharged vehicle.
Posted: Sat Nov 29, 2008 4:05 pm
by tobongoornot
Taking a closer look at the ebay page it appears to require you to git an aftermarket filter which is probably a K&N which is probably where the performnace increase comes from.
Posted: Sat Nov 29, 2008 5:25 pm
by shaun.m
these things are the biggest waste of space ever. Seen one fitted to a morgan plus 8, it was a faster car when the unit was removed and binned
Posted: Sat Nov 29, 2008 7:15 pm
by moonshine
Seems I may have been right about it restricting airflow.
Posted: Sun Nov 30, 2008 12:00 pm
by tricky
scanner wrote:
But THAT is NOT a supercharger - if anything it is an electrically powered turbocharger as it is a centrifugal blower not a linear one.?
If we're going to be pedantic then, no, it would not be an "electrically powered turbocharger". The full name for a turbocharger is "turbo supercharger" as it is a turbine powered supercharger driven by exhaust flow, so a turbocharger IS a supercharger. The item in the ebay ad, should it provide any advantage at all (questonable at the price), would be correctly termed an "electric supercharger" or perhaps "electrocharger. There are a number out there, generally much more expensive than that one, and there are varying reports of their effctiveness. The benefit of a turbocharger is it provides boost from "free" energy. It could be argued that the additional load that the electric unit presents to the alternator, and hence power sap on the engine, could outweigh the improvements seen.
I would predict that some ignition mapping alteration would be required to prevent pre-ignition if the charge boost was in any way signifcant. The emergence of electric superchargers is no doubt connected to the increased efficiency of alternators and electric motors and breakthroughs in material technology reducing inertia in impellers and resistance in bearings, enabling the balance of cost of input to be outweighed by the benefit of output in terms of input charge boost.
You also get centrifugal superchargers and these tend to be the most efficient superchargers as they use pure rotational motion direct from the engine to compress the inlet charge....
Posted: Sun Nov 30, 2008 12:32 pm
by scanner
To be a "supercharger" ANYTHING of any form (be as pedantic as you like there) must produce more air than the engine can consume at full throttle. i.e it must SUPERcharge the engine with air.
As Moonshine points out it is extremely doubtful if that pathetic device can do so, unless fitted to something like a 0.5cc glowplug model aeroplane engine.
QED it is not any form of supercharger - turbo, axial, positive displacement, linear or otherwise........................
