Page 1 of 2
over heating!!
Posted: Wed Nov 26, 2008 8:24 pm
by LEEANGE
my van over heated yesterday :cry:
i only drove home from work (about 3 miles)
didnt get stuck in traffic or stand for any length of time.
water was low so topped up with water and coolant but did the same again today!!
any thoughts???
gonna try a new thermostat :?
Re: over heating!!
Posted: Wed Nov 26, 2008 8:27 pm
by haydn callow
Doubt it's the thermostat. How low was the coolant in the tank ??
Any puddles underneath ??
Heaters blowing hot ???
Re: over heating!!
Posted: Wed Nov 26, 2008 8:35 pm
by LEEANGE
heaters are awesome, no puddles and not sure how long the coolant`s been in.
Re: over heating!!
Posted: Wed Nov 26, 2008 8:42 pm
by spout
What do you mean by "overheated"? because I've read on the fact sheets that the temp gauge can give a faulty reading.
If there was clouds of steam and boiling coolant everywhere, ignore the above :mrgreen:
Good luck..............
Re: over heating!!
Posted: Wed Nov 26, 2008 8:49 pm
by LEEANGE
i`ll ignore the above then spout!!!
sort of had a mobile sauna :oops:
have topped it up again but just hope i havent done any permanent damage!!
Re: over heating!!
Posted: Wed Nov 26, 2008 9:11 pm
by haydn callow
Didn't ask how long the coolant had been in the tank....asked how low it got??
Re: over heating!!
Posted: Wed Nov 26, 2008 9:12 pm
by haydn callow
the temp gauge go up to the HOT END ??
Re: over heating!!
Posted: Wed Nov 26, 2008 9:18 pm
by LEEANGE
sorry my mistake!!
must have been very low.
didnt even notice the gauge going up,like i said,only drove for a few minutes
and when i got out at home,noticed loads of steam coming out.
lifted the seats and steamed my windows up!
Re: over heating!!
Posted: Wed Nov 26, 2008 9:25 pm
by hogggman
you may have been very lucky if it was driven for such a short while.
i hope so,
jamie
Re: over heating!!
Posted: Wed Nov 26, 2008 9:29 pm
by jaylee
Been a lot of forum users with top hoses go lately.. :-k
Re: over heating!!
Posted: Wed Nov 26, 2008 9:30 pm
by missfixit70
It needs to be bled properly if you're not sure how low it got, but you need to find where the water's going & sort the problem & don't drive it until you do or you will kill it. Check all your hoses & pipework for leaks, see if there's any water staining.
Have there been any other issues leading up to this? sounds like one the coolant level alarm and/or the mason alarm may have picked up if fitted?
Re: over heating!!
Posted: Wed Nov 26, 2008 10:22 pm
by LEEANGE
just been out to it and ran it for about 15 mins.
heaters got hot,temp gauge didnt move :?
no leaks that i can see :-k
Re: over heating!!
Posted: Wed Nov 26, 2008 10:27 pm
by missfixit70
Bear in mind, by the time the temp gauge moves, it's probably too late ( Mason alarm resensitises the "dumbed down temp gauge), I'd get the seats up & check the hoses for bulges or pinpricks asap, could be the waterpump, check everywhere for staining from a leak that may only happen once it's up to temp/pressure, 15 minutes on the drive probably won't be enough to open the stat.
Re: over heating!!
Posted: Wed Nov 26, 2008 10:51 pm
by mister munkey
jaylee wrote:Been a lot of forum users with top hoses go lately.. :-k
Hands up. I'm one of them. Mine popped overnight, with the engine off, at the Silverdale meet a month or two ago. Thanks to the assistance of certain forum members, all was well sameday but I'd would've been b*ggered otherwise.
Top Hose Syndrome is, I believe, the first warning sign that the 10/12 year old set of rubbers have reached the end of the line.
Re: over heating!!
Posted: Thu Nov 27, 2008 4:51 am
by bigdaddycain
Don't forget to check the level of coolant before you attempt to re-start the bongo leeange, you'll be VERY lucky to have got away without an airlock... [-o<
Take some coolant along with you on any subsequent trips in case you get "caught short" somewhere... :wink: Best of luck.
