pcv valve
Posted: Mon Nov 17, 2008 5:08 pm
hi,does anyone know if there is a pcv valve on the bongo,if so where is it located? + do they have o2 sensors.
See http://en.wikipedia.org/wiki/PCV_valvecheffy34 wrote:Whats a pcv valve scanner
I know petrols have to have them and they use the manifold vacuum to do the "Positive Ventilation".The Positive Crankcase Ventilation valve, or PCV valve, is a one-way valve that ensures continual evacuation of gases from inside a gasoline internal combustion engine's crankcase.
francophile1947 wrote:See http://en.wikipedia.org/wiki/PCV_valvecheffy34 wrote:Whats a pcv valve scanner
I've never seen a diesel vacuum pump that connects to any sort of PCV valve and I don't think I'd like to see one that has been connected to one and sucking on all that goo for any length of time.dandywarhol wrote:........but they do have a vacuum pump.....There must be some form of crankcase breathing system otherwise the oil seals would pop - I'll have a squint at lushprojects pages sometime.
