cruise controll
Posted: Mon Nov 17, 2008 2:35 pm
by bongalo
Any ideas on aftermarket cruse controll could not find any when searching the forum
cheers
Re: cruse controll
Posted: Mon Nov 17, 2008 2:50 pm
by scanner
bongalo wrote:Any ideas on aftermarket cruse controll could not find any when searching the forumn
cheers
You should have found Waeco MS -50
Just a thought.....
Did you spell it as above or as "Cruise Control"?
Re: cruise controll
Posted: Mon Nov 17, 2008 3:09 pm
by Simon Jones
Loooaaaads of info on the forum. Drop me a pm with your email address & I can send you info on fitting Waeco MS-50.
Re: cruise controll
Posted: Mon Nov 17, 2008 3:34 pm
by scanner
Simon Jones wrote:Loooaaaads of info on the forum. Drop me a pm with your email address & I can send you info on fitting Waeco MS-50.
But that's if you can get one now Simon?
And with the £ at 1.18 to the Euro they are getting expensive if you find one.
Try asking at http://www.conrad-anderson.co.uk/cruise ... rolkit.htm about that model it is apparently an improved version of the MS-50.
Re: cruise controll
Posted: Tue Nov 18, 2008 12:12 am
by missfixit70
Do a search using "cruise and control" loads of results, with Siomns instructions it'll only take a couple of hours if you can get an MS-50.
Re: cruise controll
Posted: Tue Nov 18, 2008 12:15 am
by Simon Jones
Bongalo - pm sent. It looks like they are still available for £109 (sterling) + P&P. Some folk have found them cheaper, but even at this price, its still good value.
Re: cruise controll
Posted: Tue Nov 18, 2008 12:28 am
by dandywarhol
I would think twice about using this mob - The unit never left Germany although they insisted it had and took me weeks to finally get a refund. :(
Re: cruise controll
Posted: Tue Nov 18, 2008 12:32 am
by missfixit70
I got mine ok Dandy, took about 3 weeks though.
Re: cruise controll
Posted: Tue Nov 18, 2008 12:42 am
by Simon Jones
Mine was ok too. Worth noting there may still be a few pounds to be saved by getting one priced in Euros:
http://cgi.ebay.co.uk/Waeco-MS-50-Magic ... m153.l1262
It seems to be about £3.50 cheaper, but your bank may charge that much to cover the exchange of currency.
Re: cruise controll
Posted: Tue Nov 18, 2008 1:13 am
by scanner
If you use a Nationwide card (credit or debit) there are no conversion charges and usually a better exchange rate as well.
Re: cruise controll
Posted: Tue Nov 18, 2008 1:28 am
by thedogsbollox
Took me a while to get mine too. I hounded them to see where it was and they told me that the courier effed up and it is now dispatched. That took another week. I got it about 3 months ago and still have not fitted it. if there are any problems with it then i am worried that there will be problems getting a replacement/refund.
wish me luck.
|Tony
Re: cruise controll
Posted: Tue Nov 18, 2008 1:38 am
by MountainGoat
Mine is a magic Speed MS-50 one from the same place as Simon's. I had no trouble at all in getting it directly from Germany via ebay a few months ago. Still not have got around to fitting it though. :oops:
Re: cruise controll
Posted: Tue Nov 18, 2008 10:01 am
by scanner
I'm wondering if they are still advertising them but having a job actually sourcing the stock when they get an order as the MS-50 is pretty well obsolete now.
