Page 1 of 4
Coolant Alarm Yes or No??
Posted: Wed Oct 08, 2008 10:52 pm
by Becks-bongo
I am trying to decide weather to have one fitted at Woodlands or not.... and I am a bit of a sheep...Baaaa
Re: Coolant Alarm Yes or No??
Posted: Wed Oct 08, 2008 11:03 pm
by The Great Pretender
Yes...................... But it isn't a cure all problems......................A fact sheet should be out soon.
Posted: Wed Oct 08, 2008 11:04 pm
by mister munkey
As a lazy bloke, I will fit one on any other vehicle I ever get. Peace of mind & insurance against that "I'll check the levels tommorow" state of mind becoming expensive.
Posted: Wed Oct 08, 2008 11:17 pm
by lizard
mister munkey wrote:As a lazy bloke, I will fit one on any other vehicle I ever get. Peace of mind & insurance against that "I'll check the levels tommorow" state of mind becoming expensive.
and it beeps.
Posted: Wed Oct 08, 2008 11:18 pm
by daveblueozzie
i have a coolant alarm i fitted myself last year, it gives me a reassurance that when i start my engine in a morning i still have coolant in there to do the job its supposed to. and to know that with any luck ,it will tell me in time that i am losing coolant as i am driving.
it does not replace checking the levels ,but it helps me being a lazy person not to worry if i miss checking now and again.
Posted: Thu Oct 09, 2008 10:04 am
by haydn callow
Every Bongo should have one.....but then I have my self interests at heart.
To be serious....go to
http://www.coolantalarm.co.uk and click on testimonials.....have a read and make up your own mind.
Posted: Thu Oct 09, 2008 12:02 pm
by Magwa
Er no but I poured K seal into the system and the level is the same now as the day I did it
( 10k miles later)
I am religious about checking the level before and after a long journey
( I've owned a K series engined Landrover Freelander......Oh I know!)
& I can smell antifreeze at 100paces which helps!
Posted: Thu Oct 09, 2008 5:14 pm
by dandywarhol
No but I have fitted a Mason alarm. I also regularly check the level and think the Mason alarm covers more possible overheating senarios.
Posted: Thu Oct 09, 2008 6:29 pm
by waycar8
dandywarhol wrote:No but I have fitted a Mason alarm. I also regularly check the level and think the Mason alarm covers more possible overheating senarios.
Agreed
, i too have the masons alarm, you can fit it yourself in under 15 minutes, just a case of undoing a few screws to get to the clocks and putting it at the back of the temperature clock on the dash by undoing the 3 small screws fitting the wires and putting the screws back in.
both alarms have the merits but the masons alarm comes up on top IMO, as it shows the temperature gauge in its true engine temperature state, weather your driving and you have an air lock and starts to overheat, it will alarm and show the reading of how hot the engine is, if you had the coolant loss alarm fitted it will only alarm if theres no coolant in the header tank after you have overheated and lossed coolant.
the coolant loss alarm will alarm and tell you when you first got in to your bongo and turned on the ignition, if you have had a coolant leak through the night and the header tank is empty, the masons alarm wont!(But the masons alarm will go off after you have started to drive and the engine has heated up anyway),and the coolant loss alarm will also tell you if you blow a hose whilst driving, but theres the chance even thoe you have blown a hose and lossed your coolant there can be back pressure causing the header tank to stay full of coolant and the alarm wont go off!
loads op people have both fitted but i only have the masons alarm,bacause for the price of the masons alarm compared to the coolant loss alarm especially with the masons alarm that helps to stop a cooked engine/head by monertering the actual heat in the engine does it for me, the coolant loss alarm just tells you if you have lossed coolant out of the header tank so the masons alarm comes up on top for me.
Cheers Wayne
Posted: Thu Oct 09, 2008 6:58 pm
by petebee
haydn`s coolant level and the Mason temperature alarm are must have gadgets as far as I`m concerned.
Full peace of mind motoring.
Posted: Thu Oct 09, 2008 7:10 pm
by Becks-bongo
Maybe i should have put mason as a choice... but i have never heard of them.. and am unsure what they do!
am looking forward to reading the fact sheet.....
Posted: Thu Oct 09, 2008 7:12 pm
by Wedge
Are Bongo's really that prone to overheating?
Is there a design flaw or something?
Posted: Thu Oct 09, 2008 7:42 pm
by waycar8
depends how you look at it, at the end of the day they are 10+ years old, so the coolant sytem is well used and so are the hoses and the rad is sometimes blocked up over time ect ect, also alot of people dont know about bleeding the bongo using the bleed hose under passenger seat, not bleeding it right will end up with airlocks leading to overheating ect ect, and with the head been ali and has had 10 years of hammer, its easilly cracked after an overheating issue thus resulting in an expensive repair up to 1500 quid, so prevention is cheaper than the cure.
Posted: Thu Oct 09, 2008 8:07 pm
by Lloydy
Yes you should fit one.
They dont cost the earth, are easy to fit and give peace of mind. Mine has already indicated a problem and enabled me to fix it before it was too late!!
Its not rocket science. The gadget tells you if your coolant level is ok.... We all need to know that!
I know you can look, and i do, but its still saved my engine!
Lloydy.
