Page 1 of 2
Rear air con/heater fan
Posted: Mon Sep 22, 2008 10:52 am
by muddypaws
Well, everything in the front works fine.
The rear however, nothing whatsoever!
DH has checked all fuses and they are all fine. There is power to the switch in the front which you flick to turn the rear 'on'. But still nothing. Anyone know where the relay is hiding please?
Re: Rear air con/heater fan
Posted: Mon Sep 22, 2008 12:58 pm
by francophile1947
Have you got the front fan turned on? I don't think the rear works without it, but I'm not 100% sure as I've never used my rear heater.
Posted: Mon Sep 22, 2008 2:03 pm
Also the rear heater master switch to the right of the steering wheel and below it on the dash.
Posted: Mon Sep 22, 2008 2:18 pm
by Simon Jones
Digital heater controls or manual? The digital version has a 'rear' button & green light on the main unit, whereas manual has the seperate switch as mentioned.
Posted: Mon Sep 22, 2008 3:12 pm
by muddypaws
Didn't explain myself very well. Yes have done all that. Its definitely not working.
Posted: Mon Sep 22, 2008 5:59 pm
Hmmmm. Has it been seen working before in your ownership? Is your a kitchen conversion Bongo, as some converters remove the rear heater assembly.
Failing all that, then its down to systematic testing. Is it a climate Control system or the simple aircon system?
Posted: Mon Sep 22, 2008 6:06 pm
by muddypaws
My hubby is an air con engineer so I'll get him to post later as he knows what he's talkin about!
Posted: Mon Sep 22, 2008 6:36 pm
by muddypaws
Its all there....the whole kit and caboodle...its a simple air con system. Just no air coming out of any of the vents cos the fan doesn't come on!
Posted: Mon Sep 22, 2008 9:48 pm
by Bob
Mine hasn't ever worked either, but since it's just the two of us I'm leaving it.
Posted: Mon Sep 22, 2008 10:36 pm
I guess you have to get a multimeter on the case and see if power is getting through to the fan etc. Also, what fuse might it be that looks after the rear fan. Did you say it was working before?
Posted: Tue Sep 23, 2008 8:39 am
by muddypaws
We've done all that Mike, theres power everywhere. dh has a multimeter.
We just wondered if there was a relay somewhere.
Posted: Tue Sep 23, 2008 8:58 am
by helen&tony
If there's power everywhere, then the fan is goosed....not a hard job....I did mine....same symptoms...If you need instructions, just ask
Posted: Tue Sep 23, 2008 9:20 am
Sounds like Helen should be able to guide you.
Out of interest, I'm still not clear. Have you ever had the rear fan running successfully? If there is a failed relay, the you won't be getting power at the fan, so power can't be everywhere. I suppose if it were me, I would try putting 12v direct across the fan to see if it sprang to life. Duff relay sounds a distinct possibility but hard to point a finger at it without knowing if the fan was working until recently then suddenly stopped working.
Posted: Tue Sep 23, 2008 9:42 am
by muddypaws
Sorry Mike, no we've not had it working since we got it!
Posted: Wed Sep 24, 2008 9:06 pm
by muddypaws
