remove rear spoiler
stansyerman
remove rear spoiler
Post by stansyerman » Sat Sep 06, 2008 9:05 pm
any tips on removing the rear spoiler need to take it off and send it away to get cut to fit a bike rack
You've Been Bongod
Re: remove rear spoiler
Post by You've Been Bongod » Sat Sep 06, 2008 9:29 pm
hi Stansyerman
lift the tail gate and on the outer edges there will be 2 bolts on each side
undo them and lift
but watch the wires for the brake light
they should be on snap connector
hope this helps
you've been bongod
Jolly Rogers
Post by Jolly Rogers » Sat Sep 06, 2008 9:32 pm
#-o beat me to it.
Post by bigdaddycain » Sun Sep 07, 2008 1:49 am
There's a good chance that there will be body moulding tape in place too if the spoiler has been removed in the past for any reason. Steady as ya go.... :wink:
stansyerman
Post by stansyerman » Sun Sep 07, 2008 8:39 am
the wires for the brake light on the snap connector do i have to remove interior panels to get to it
Post by Ian » Sun Sep 07, 2008 8:43 am
No, it's just a plug. You will see it when you (slowly) remove the spoiler. But before pulling the plug apart, take measures to make sure that the lead does not disappear inside the spoiler (like wot I didn't do and had to get a wire coat hanger.......) :oops:
Post by bigdaddycain » Sun Sep 07, 2008 9:09 am
I was just gonna add something to that effect ian.... After releasing the plug connector, "bulk out" the actual plug part by wrapping insulation/masking tape around and around the plug, till its so big it physically can't drop inside the tailgate to the depths of nowhere! :shock:
Jeff & Sally
Post by Jeff & Sally » Mon Sep 08, 2008 9:25 pm
Before you cut the spoiler consider getting some new top brackets made.
Ive just had some done for my t4 rack they will fit with the spoiler just have to cut & drill the top of the rack. Havent got round to refitting yet, will try to post some pics when I do.
