Loosen my nuts
Jolly Rogers
Loosen my nuts
Post by Jolly Rogers » Sat Sep 06, 2008 7:42 pm
I am trying to remove my sidesteps on my Bongo. I managed to get one side off no problem. The other side all the bolts on the other side won't budge :oops: , Any idea how I can loosen them? The bolts have cross head on them, maybe impact screwdriver :? or spray them with somehing so I can loosen my nuts [-X The ones on the sidesteps :oops:
westonwarrior
Re: Loosen my nuts
Post by westonwarrior » Sat Sep 06, 2008 7:44 pm
can allways drill them off
why you removing them?
Jolly Rogers
Re: Loosen my nuts
Post by Jolly Rogers » Sat Sep 06, 2008 8:08 pm
Me use a drill near my beloved Bongo :shock:
I want to replace the rusted bolts with some nice shiny ones :oops:
ford tinny
Re: Loosen my nuts
Post by ford tinny » Sat Sep 06, 2008 8:55 pm
Hello,
I replaced rusty old bolts on my sidesteps too with nice stainless steel ones
http://cgi.ebay.co.uk/M8-X-30-A4-GRADE- ... m153.l1262
Two packets of the above
http://cgi.ebay.co.uk/8mm-STAINLESS-STE ... m153.l1262
http://cgi.ebay.co.uk/M8-STAINLESS-WASH ... m153.l1262
One packet of the above
Looks fantastic and no more rusty bolts EVER!!!!!!
Thanks John
cheffy34
Re: Loosen my nuts
Post by cheffy34 » Sat Sep 06, 2008 11:02 pm
Jolly Rogers wrote:Me use a drill near my beloved Bongo :shock:
better option than a chizel and gentle persauder :D
Re: Loosen my nuts
Post by bigdaddycain » Sun Sep 07, 2008 1:47 am
Try tightening the bolts, then loosening. Make or Break (literally).
Also try centre punching the very centre of the bolt,(carefully!) Sometimes, (in conjucntion with penetrating fluid), this can persuade the "seal" to be broken...
tricky
Re: Loosen my nuts
Post by tricky » Sun Sep 07, 2008 12:47 pm
ford tinny wrote:Hello,
Thanks John
Careful now. Putting Stainless together with Mild steel can result in galvanic corrosion of the mild steel. If the Stainless is a bolt and the Mild is the body of the vehicle you may end up with more costly corrosion than that of a bolt. The Mild steel can corrode sacrificially to the Stainless as it is more reactive. With the amount of salty water on out roads in winter this could be a costly cosmetic gain. The relative mass of the anode versus the cathode affects the rate or occurance of corrosion so you might get away with it if the bolts are small in mass versus the area to which it is attached.
You'd probably be safer using zinc galvanized bolts, where the zinc plating is designed to be sacrificial to the steel (being more reactive).
I've noticed rapid corrosion of the screws used to attach my Fiamma F45 awning to the stainless brackets due to the meeting of non-reactive stainless with the mild steel screws.
Jolly Rogers
Re: Loosen my nuts
Post by Jolly Rogers » Wed Sep 10, 2008 1:10 pm
Well no success as yet :( I have managed to blunt 3 drill bits #-o , off to buy some more drill bits wish me luck [-o<
Re: Loosen my nuts
Post by bigdaddycain » Wed Sep 10, 2008 1:20 pm
Did you centre punch the boltheads first JR? Use the narrowest drill bit you think you can get away with at first, once you have made a small hole, you have a better purchase for a bigger drill bit.
Jolly Rogers
Re: Loosen my nuts
Post by Jolly Rogers » Wed Sep 10, 2008 1:29 pm
These bolts have phillips crosshead on them. I started off with a small drill bit and worked up to bigger one, Still managed to blunt my drill bits and annoy my neighbours with all the noise :roll:
Re: Loosen my nuts
Post by francophile1947 » Wed Sep 10, 2008 1:40 pm
Can't you get a small grinder to them?
Jolly Rogers
Re: Loosen my nuts
Post by Jolly Rogers » Wed Sep 10, 2008 3:18 pm
Don't own one :( also she is lowered so nut much room underneath 8)
Re: Loosen my nuts
Post by bigdaddycain » Thu Sep 11, 2008 12:04 am
I don't have original sidesteps fitted, are the bolts conventional heads with a cross-headed centre? I'm guessing the bot heads have rounded off? Is there enough room to get a pair of vice grips on them? It may shear the heads,but at least you'll have a (hopefully) clean flat surface to work with [-o< [-o< [-o<
Jolly Rogers
Re: Loosen my nuts
Post by Jolly Rogers » Thu Sep 11, 2008 5:59 pm
They are round headed bolts with cross head in them. They just don't want to budge](*,) I want to put them on my Aft. Still trying to convince her in doors to let me keep the Bongolow she's gorgeous ooh and so is the wife.
