should i bleed?
Posted: Thu Aug 07, 2008 12:18 pm
Could a seasoned expert give me their view pls?
i had a coolant pipe changed, garage was informed of bleeding process.
after collection and drive home, next morning coolant level needed just a small top-up, there was still coolant in the header tank
both front and rear blowers produce lots of heat
given it several hour long runs with rock solid 11 o'clock reading
so it all sounds good so far...
I checked the bottom hose from rad today after a short run up to temp and it was still cold, all the other accessible ones were hot.
Should i be concerned and bleed again?
many thanks in advance, driving to France at weekend so just a bit paranoid!
cheers,
bongalong
cheers,
bongalong
