My Air Con is Naff
Posted: Sat Jul 26, 2008 8:35 pm
by thedogsbollox
After suffering the last 2 days in baking sunshine, i need to get my aircon sorted. It used to be real good but lately it does not seem to have any uumph. I have heard that Halfords will re-charge it for about £40. Would this be my first option or are there any other things i should look at first?
Tony
Re: My Air Con is Naff
Posted: Sat Jul 26, 2008 8:42 pm
by splitpin
Mine wasn't working good also, I had a mobile air-con man to check it over, all it needed was re-gassing. Cost £40.
Posted: Sat Jul 26, 2008 8:50 pm
by David Edwards
Check out kwik fit, they had an offer of fixing it for £25.00 or no charge if no luck.,
Posted: Sat Jul 26, 2008 8:59 pm
by thedogsbollox
Another question is, Can re-gassing be done yerself?
Posted: Sat Jul 26, 2008 9:02 pm
by francophile1947
David Edwards wrote:Check out kwik fit, they had an offer of fixing it for £25.00 or no charge if no luck.,
It's £49.95 at Kwik-Fit here
Posted: Sat Jul 26, 2008 9:05 pm
by francophile1947
thedogsbollox wrote:Another question is, Can re-gassing be done yerself?
You can get kits to do your own. I've never tried them, but others on here have with, I believe, mixed success.
Posted: Mon Jul 28, 2008 7:47 am
by Veg_Ian
The trouble is with diy is that you don't know how much gas you have in the system to start with. A can of gas will cost you about £25 if memory serves and you would probably need two to fill the Bongo. For the same price you can have your system checked, evacuated and refilled to the correct weight of gas, for the same price by an expert (I use the term loosely when including Halfrauds etc).
Posted: Mon Jul 28, 2008 8:55 am
by thedogsbollox
Veg_Ian wrote:The trouble is with diy is that you don't know how much gas you have in the system to start with. A can of gas will cost you about £25 if memory serves and you would probably need two to fill the Bongo. For the same price you can have your system checked, evacuated and refilled to the correct weight of gas, for the same price by an expert (I use the term loosely when including Halfrauds etc).
Thanks for that, i think i will leave it to the experts. Now when the expert asks, "A Bongo what?" Where should i point him to find the place to fill it?
Posted: Mon Jul 28, 2008 9:48 am
by annsvan
my "expert" had problems here!!! one port is obvious, infront of the radiator, the other less so but obvious once sighted it is behind the radiator
cheers
Posted: Mon Jul 28, 2008 9:51 am
by Veg_Ian
Hmm going to have to show my ignorance here. The High pressure valve is located just in front of the rad (light blue cap) but I'm pretty sure you need to fill from the low pressure valve. Which is hidden somewhere behind the rad. I dunno, it's been a while since I touched aircon. Hopefully someone will correct me on this and point out which one it is filled from.
Posted: Mon Jul 28, 2008 11:13 am
by handyman
Hello guys , long time no post.
My aircon is f***ed to. My air con man is on holiday but suggested Kwik fit for a Kwik fix.
But lot's of the usual head scratching, shrug of shoulders and " can't do it co's the specs are not on the system mate"!
They want to know gas weight and oil mix so they can press buttons on the computer
My aircon bloke takes an hour to do the job. He pumps out the old gas weighs it then pumps in fresh gas with a little bit more to fill the vacuum after testing the system for leaks.
Can Kwik Fix do that? "Nah, we need the specs mate"
The last time I had it done was 3 years ago so I ain't done to bad...pitty it's packed up co's "It aint half hot mum"!!
Posted: Mon Jul 28, 2008 9:24 pm
by thedogsbollox
Thankyou all for the assistance.
Much appreciated
Tony
Posted: Mon Jul 28, 2008 9:56 pm
by madmile
You can DIY fill quite easily, but if you can get someone to do it for around £40 its not worth the hassle.
I just put a bongo on the road that hadnt been used for 6 mths - air con not working. I did buy one of the fill up kits a while back that have a guage on and the refil cans are about £11 so not too bad - however I used one and it worked for a week. Then tried a small can of air con sealer plus another can of refil - now working OK - cost around £30 plus an hour faffing around trying not to get frost bite
PS the low pressure valve is the one behind the rad quite low down - cap should have an 'L' on it.
Posted: Tue Jul 29, 2008 12:09 am
by thedogsbollox
Will have a look for both before i try to point them out to el thicko
Thanks guys
