Electric Windows again!
Posted: Mon Jun 30, 2008 3:43 pm
OK - i have just been all through the forum looking for "electric windows" and their faults and know it is probably the cables between the door and the door post. Before i start hacking these apart i wondered several things
1. Mine is odd in that it is the passenger window and it will not work from either switch.
2. I have taken the passenger switch to pieces completely and it looks OK [cleaned off loads of carbon]. Still does not work.
3. Big black wire seems to have power in it in the passenger door.
4. I have applied 12v to the window cables directly and the window goes up and down OK
5. Is there some link cable that could have gone between the drivers switch and the passenger switch that would have knocked them both out?
How it happened: Wife got in the car [passenger side] late at night and we drove off from friends. She lowered window to say goodbye and it would not go up again. So therefore it went in the down position. Door was not being opened at the time.
It took some prat from the RAC [subbie] 2 hours to try and fix it - he wanted to try and GRIP the window and lift it! i could hear it being torn from its mounts. In the end i took off the door panel and released the motor from its location and the window was then liftable. Got to bed at 4am!
