furred up negative terminal on leisure battery
Posted: Wed Jun 25, 2008 8:35 pm
by hogggman
hi all,
i`m intermittently losing all leisure battery electrics.i haven`t investigated in depth yet,but have notice a lot of furring/white crud around the negative leisure battery terminal,could this be the cause,or just because of a loose terminal?
thanks
jamie
Re: furred up negative terminal on leisure battery
Posted: Wed Jun 25, 2008 8:42 pm
by Simon Jones
Does sound like problem. If it were me, I'd remove both connectors & clean up each clamp & battery terminal with a small wire brush or some fine sandpaper. Then smear both surfaces with petroleum jelly (Vaseline) which will prevent futher oxidation, but without affecting the electrical conductivity. Good luck.
Posted: Wed Jun 25, 2008 9:19 pm
by bigdaddycain
The sanding of the terminals will increase the conductivity of the connections too, but only temporarily unless the terminals are protected from the damp, as simon suggests....
I use copper grease, this helps to promote a good electrical contact.
Posted: Thu Jun 26, 2008 12:25 am
by cheffy34
Yip i use a little copper grease aswell, top tip tho don't leave the tin infront of your van trust me it makes a nasty mess when you forget it and drive over it
Posted: Thu Jun 26, 2008 12:33 am
by bigdaddycain
Doh!
It's not exactly the cheapest grease in the world either cheffy...
Posted: Thu Jun 26, 2008 12:48 am
by cheffy34
bigdaddycain wrote:Doh!
Pays to have a mate in the trade
who hates working on jap cars, gives me all his tools n stuff to keep me out of his workshop says go on if you get in trouble gimme a shout i'll come and laugh/help he left it at my house and said it yours said i'd never have to buy it again in my life time it goes for ever
reckon i managed to save enuf to see me to retirement
Posted: Thu Jun 26, 2008 12:51 am
by bigdaddycain
That's true, it does go a LONG way! I bought the tin i have about ten years ago, and it'sstill nearly full! I'll lose it before i use it.
