How deep can we go?
Posted: Thu Jun 05, 2008 2:33 pm
by Noggin the Nog
With all the flooded water of the past few days I have been wondering how deep can we go in our Bongo's?
I went down one flooded lane and passed easily through 15 - 20 inches. The air intake is quite high in the front grill area so no probs there. How deep have others been?
Re: How deep can we go?
Posted: Thu Jun 05, 2008 4:01 pm
by jaylee
Just getting the tape measure out, i found myself down a lane near Bristol a few months back which was so heavily flooded even the big boys 4x4's didn't want to chance it..
It could have been 23" at the deepest. i don't know??
I felt like the Titanic but carried on..
Though i was crawling through the flood the wash looked as if it was covering the lights at one point, the road inclined back up & i got out no problem.
I did however lose a wheel trim & the inter cooler air scoop (which is as its name suggests is not for scooping heavy volumes of water) was torn off.
I managed to source a replacement scoop, the original being twisted beyond repair..!
My mate on the other hand was in a Citroen estate following a few minutes later, wrote his off he reckoned 6 inches of water was in the car when they pulled him out!!
I'm also reliably informed Badgers don't do air scoops any favours either.
Posted: Thu Jun 05, 2008 4:13 pm
by tricky
I had a Citroen XM years back. Had to shift it one day during heavy rain as it was parked near a partially blocked drain and with the suspension in the down position it was close to filling up.
Posted: Thu Jun 05, 2008 4:59 pm
by Noggin the Nog
Have had another look at the air intake system and although the open end is high enough at the front it does drop down before it raises up to the air filter. A good inspection of this plastic piping might be advisable to check for splits and holes etc. If this is OK I reckon our bongos should get through anything the 4x4 brigade can. It might be as well to go slowly through the water so as not to remove other bits of "trim" below like the plastic underengine shield etc. Do we all agree?
Posted: Thu Jun 05, 2008 8:07 pm
by bigdaddycain
When traversing deep water, it's adviseable to match the speed of the bow wave as closely as possible, this helps to keep the exhaust tip in the same area as the "wake" too.
Posted: Sat Jun 07, 2008 3:02 pm
by tobongoornot
jaylee wrote:I'm also reliably informed Badgers don't do air scoops any favours either.
Did not do mine any favours
. To be fair though I think the badger came off worse.
Posted: Sat Jun 07, 2008 7:21 pm
by dipstick
I would take the max depth of water you can traverse is below the base of the alternator bracket or you are going to short out the electrics if the alternator is submerged, this is a good few inches/mm below the height of the air inlet under the bonnet.
Posted: Sat Jun 07, 2008 11:52 pm
by jaylee
tobongoornot wrote:jaylee wrote:I'm also reliably informed Badgers don't do air scoops any favours either.
Oh yeah, the Badger will trade it's life for the damage caused..
A friend of mine had an RS2000 written off once by Bill Odie's best mate.
