side repeaters
Posted: Wed Jun 04, 2008 4:24 pm
by ribbleman
Hi All, Anyone fitted side repeaters/ are they easy to wire in and how is it done
many thanks steve
Re: side repeaters
Posted: Thu Jun 05, 2008 10:37 am
by apole
I haven't fitted them but was loaned a bongo recently that had them. They were fitted to the backs of the mirrors, looked pretty neat. I guess you just tap them into the relevant indicator wiring from the front indicators.
BTW the ones looked to be LED, I think Hella do stick on LED kits.
You would need to remove the front door cards and trace the wiring through the conduit between the bodywork and doors.
Hope this helps.
Andy
Re: side repeaters
Posted: Thu Jun 05, 2008 7:56 pm
by bigdaddycain
My bongo has them fitted, they are simply daisy chain wired into the front indicators +ve and -ve wiring like for like. The plastic inner arch will need to be removed from the front wheelarch if fitting to the front wing, then re-fitted afterwards of course.
Just remember to treat any holes drilled against rust,luckilly i was changing my original orange side repeaters for some smoked items, when i noticed that the hole that had been drilled by the importer were untreated, and rusty around the drilled lip, i treated it with with acid etch primer after filing away the rust.
Re: side repeaters
Posted: Mon Jun 09, 2008 7:22 pm
by ribbleman
Hi thanks for replies this will be project for weekend
thanks
