More fault codes
Posted: Fri May 16, 2008 10:10 pm
Hi Folks, my Bongo recently had transmission trouble with it dropping in to safe mode after an hour or so with the hold light flashing, so after following instructions in the members area on how to extract the error codes, I popped along to a transmission specialist in Hove who gave me the following translation..
9 : Engine Coolant Temp
11 : Intake Air Temp
12 : Throttle position sensor
16 : EGR valve position Sensor
60 : Shift Solenoid A
61 : Shift Solenoid B
I thought this would be worth posting since some of these aren't on the fact sheet
The specialist I saw also said several of my codes were probably old and erroneous and that I should briefly disconnect the battery to clear them, then
do a long drive until the fault re-appears, then re-check the codes. Sure enough the faults turns out to be just 60 and 61, still £400+ to fix tho
I also found a page on about.com with fault codes for 1995 Mazda.. http://autorepair.about.com/library/ts/ ... cs-76a.htm
These look right for the Bongo, has anyone had other codes to confirm?
Hope this is useful
Hope this is useful
