heater fan problem
Posted: Thu May 08, 2008 8:25 pm
by lorne444
I have a problem witth my heater fan. It doesn't work when switched on for the front but works correctly for the rear passenger seats at all speeds. Does this mean that there are 2 independent fans for the climate control? If so where are they? If not how does this behaviour arise? I suppose that there are fuse(s) for any fans and would like to check these. Where are they? There is apparently no fuse in the box in the driver's seatwell, only for aircon. Can anyone help? Thanks
Re: heater fan problem
Posted: Thu May 08, 2008 8:33 pm
by francophile1947
The heater fan fuses are in the fusebox under the bonnet - see fact sheet in member's area.
Posted: Fri May 09, 2008 5:55 pm
by Rhod
Frnt heater fan motor failing due to water collecting in the housing and/or buring out the resistors is a common fault. Plenty of info if you do a search. Or in members factsheets.
Posted: Fri May 09, 2008 10:06 pm
by Doone
Yes there are.
As has been said, it's likely that the front fan has seized. Edit: They suffer with water ingress, which can cause the fan to eventually seize.
The new heater motors have a drain hole and modified pipe, so the water can escape.
There is a fact sheet in the members area and plenty of info on the forum. :)
